Sponsored by:
Sponsored by: CARiD
Aackshun's VQ35DE Swap Plans...
Old Sep 12, 2011 | 05:05 PM
  #201
SurraTT's Avatar
HR Swap Pioneer
Originally Posted by aackshun
OK! So I talked to the shop and things are seeming on the up and up!
The plan is to fully swap a 07+ Altima VQ35DE with an 07+ Altima V6 harness and Haltech PS1000 for a Z33
This somehow keeps me in my original budget too!!!!
Now to source me a motor!
Shop??
Quick ? can the ps1k control 2 intake cams?
EDIT: guess it can since u say z33 i have never herd or a ps1k on a z33 tho. Link?
Old Sep 12, 2011 | 06:58 PM
  #202
aackshun's Avatar
Originally Posted by SurraTT
Shop??
http://powerfabauto.com/
According to them PS1K w/ a patch harness for a Z33 will work, I had the ECU's today while talking to them, they even said worse comes to worse they'll take the stock 07 Harness and use that to hard wire into the Haltech.
On the other hand... This seems like something up your alley Darren
But with the prices we discussed we somehow made it back within my original budget somehow, so I'm glad for that.
Old Sep 12, 2011 | 07:03 PM
  #203
Flava_24/7's Avatar
Boosted Panda
You still anticipate having this completed by Oct?
Old Sep 12, 2011 | 07:27 PM
  #204
aackshun's Avatar
Aw haleee nawww, incase you missed out I had to buy another 6MT, lost 4th gear in mine right now, set me back another two weeks.
My current goal is 11/15 IFO in Dallas.
Old Sep 13, 2011 | 08:31 AM
  #205
aackshun's Avatar
http://cgi.ebay.com/ebaymotors/GSP-8...ht_3629wt_1009
Found that by mistake... Hrmmm....
Old Sep 13, 2011 | 01:47 PM
  #206
doublea's Avatar
Nice and it's compatible with the TPS.
Old Sep 15, 2011 | 06:30 AM
  #207
aackshun's Avatar
http://cgi.ebay.com/ebaymotors/2-New...8#ht_969wt_939
*do want*
That plus two RX7 wheels for 130 shipped.... Mannnnn I need to buy a motor first
Old Sep 15, 2011 | 09:21 AM
  #208
Shift_Max's Avatar
Why not get the Haltech platinum that is made for the z33 then?
Old Sep 15, 2011 | 09:55 AM
  #209
aackshun's Avatar
I think that's what I meant to say?? They make plug and plays for the HR motor correct?? Then we're all guuuuud.
Either way, I showed them the ECU (07+ Altima), the individual said yeah, this will work.
Old Sep 15, 2011 | 10:44 AM
  #210
Flava_24/7's Avatar
Boosted Panda
*do want*
Um, yeah. Buying a motor might be a good start to your project,LOL.
GL, you still have over a month.
Old Sep 15, 2011 | 10:58 AM
  #211
Shift_Max's Avatar
Haltech Platinum plug and play is only made for the vq35de motors. Haltech does not make a plug and play harness for the VQ35HR motor for some odd reason. However Injected Performance which is now Dynosty makes a harness to use the Haltech Platinum on the VQ35HR motors.
http://www.injectedperformance.com/n...anagement.html
Old Sep 15, 2011 | 11:11 AM
  #212
SurraTT's Avatar
HR Swap Pioneer
Wait what????
I thought your talking about the Haltech Sport 1000 ecu??
Different fron the Haltech Plug and play platinum pro 350z unit.
Old Sep 15, 2011 | 01:09 PM
  #213
aackshun's Avatar
Wait what????
After some research....
Ughhh now I'm confused... Time to give em a call....
Either way I'd be set with both units, just some harness work....
Old Sep 15, 2011 | 01:17 PM
  #214
SurraTT's Avatar
HR Swap Pioneer
A Platinum Sport 1000 ecu has 4 injector outputs. i havent looked at it a lot but idk if it can control 2 intake cams either.
Id suggest the PNP Platinum Sport 350Z unit, like i linked one FS on the Z forums. Ive wired one up for a 4th gen full 3.5 swap and its bad ***!
BTW im still wondering if you plan to use a stock ecu??? If you dont have obd2 worries, and want to run a cable TB then id suggest the Platinum Sport 2000. Its more of a Standalone as it can control fuel pump, fans, etc..
Old Sep 15, 2011 | 01:28 PM
  #215
aackshun's Avatar
Ah you're right, it must be the PNP Z33 Plat they're talking about then. I knew it was something Platinum Z33 and PNP just couldn't figure it out, so much ECU talk going on I was confuzzled, anywho, that's the unit we discussed and it covering what I need it to cover (6 INJ's, 6 Coils, CPS REF, CPS POS, Cam POS, My old VSS and TPS sensor and Launch Control).
Old Sep 15, 2011 | 01:30 PM
  #216
SurraTT's Avatar
HR Swap Pioneer
^ oh ok, i understand!!
Stock ecu?? lol PM me if u have to??
Old Sep 15, 2011 | 01:42 PM
  #217
aackshun's Avatar
Nooo! No stockness in my car!
Old Sep 15, 2011 | 04:16 PM
  #218
ampire's Avatar
Looks like you are well on your way dude
Old Sep 16, 2011 | 06:50 AM
  #219
aackshun's Avatar
Thanks!
Ok now to clarify things up a bit.
- Haltech Platinum Sport 2000 w/ Harness (someone *coughcoughdarrencoughcough* is going to have to wire it to a 07 alty harness)
- 07+ Altima 3.5 with Harness
- Someone's Stage 2 cams (JWT, Crower, Tomei)
- Stock Z33 Injectors
- Minor Head Porting
- HR head gasket+Mod
- HR Head Bolts
- FPR Regulator
- Walbro 255lph
- ARP Rod Bolts
That's really it... keeping it pretty stock now to make room for Haltech's $$$$
From what I've seen, I do not think I will need to rev higher than 7200rpm but if I find a good deal on retainers and springs then well hell of course I'll get em.
Finish date... Yeahhhhh.... At the rate *isht keeps happening I'd be very lucky to make IFO in Dallas, but with the downs must come ups? Yeah... yeah...
Old Sep 16, 2011 | 07:44 AM
  #220
SurraTT's Avatar
HR Swap Pioneer
Thanks!
- HR Head Bolts
- FPR Regulator
- Walbro 255lph
- ARP Rod Bolts
Now its getting gooooood!
You could save some major money by not even removing the heads. Since your keeping stock pistons n such. All that money and work just dont seem worth it to me. ESP on these heads. This aint that old DE stuff! Also you could do injectors and fuel pump later on. That would probably help out.
Do the 07 motor
You need to use HR type cams (signal plate bolts on then end of cam)
Z injectors, or some 380's
Arp rod bolts
Fuel pump
FPR
Haltech PS2k (with dual widebands, and gauge if u want)
BAD *** on a decent budget!
Biggest $$$ in order
Haltech
07 motor
Cams
Old Sep 16, 2011 | 08:14 AM
  #221
aackshun's Avatar
Do the 07 motor
Arp rod bolts
Fuel pump
FPR
Haltech
07 motor
Cams
You peep'd the order I see
Anywho, play the waiting game now, can't think of much else that can go wrong for me that has already....
Tranny, being fixed...
Exhaust, being fixed...
Motor mounts, being fixed....
Axles, purchased ANOTHER driver side already.... (passenger is still good!)\
I already got a ticket, and my car has already been hit, so all of the bad stuff has already happened to me! No more delaying (I hope)
Sooo.... Yeah.... car is waitin on a motor!
Old Sep 16, 2011 | 08:23 AM
  #222
krazy6's Avatar
Thanks!
- HR Head Bolts
- FPR Regulator
- Walbro 255lph
- ARP Rod Bolts
Looks like a good list to me.
Should run good.
Old Sep 19, 2011 | 11:00 PM
  #223
mightyMax95's Avatar
q45 can be had for 50 and already has sensors and cc pulley
Old Sep 19, 2011 | 11:34 PM
  #224
aackshun's Avatar
Too big IMO, more concerned about velocity at lower rpms right now.... I talked to some other guys (really only one nut thinks this so for an N/A application), it seems at WOT 90MM would be sufficient for a modded VQ35
Old Sep 19, 2011 | 11:58 PM
  #225
80mm q tb is too large but you want to run a 90???
Old Sep 20, 2011 | 06:22 AM
  #226
aackshun's Avatar
80MM is what I wanted, but other say 90 is fine, I think they are cray-crayyy.
But who says I'm sane? I'll probably give it a shot
Old Sep 20, 2011 | 06:49 AM
  #227
ajm8127's Avatar
I don't think the diameter of the TB matters as much as the diameter and length of the tubing leading to it, as long as the TB doesn't create a restriction. Consider that the throttle body is only about 75-100mm long, and it flows directly into the plenum, which is a large volume relative to the diameter of the TB. If you increase the size of the TB, which is analogous to increasing the intake tubing size, by 10mm for only 75-100mm, I don't think there will be a large reduction in momentum when you consider the entire intake system.
Even if the TB is 90 instead of 80, there is going to be a long column of air in the intake tubing that contributes towards adding momentum to the charge for low end torque. If you want more momentum (though increasing velocity or mass), lower the intake tubing size or increase its length. Of course the flow losses increase with velocity and length, so that smaller, longer tubing will become a restriction as more air flows through it limiting high end hp.
Momentum = the velocity of the intake charge * the mass of the intake charge. The velocity is increased by decreasing the tubing size while the mass in increased by making the tubing longer, which creates a more massive column of moving air.
The trick about intakes and exhausts is not to think of them in a steady state. The volume of air flowing through them is changing as a function of the engine's rpm. So if you want your engine to feel torque-y at 2500 rpm, don't expect loads of hp at 6500 rpm. Not without having an intake/exhaust system that changes shape to maximize VE at all RPMs.
Bottom line: buy the damn q45 TB!
Old Sep 20, 2011 | 06:58 AM
  #228
Crusher103's Avatar
JWT Cams>the other stuff.
JWT offers the most lift out of all the aftermarket cams offered: More lift=Better breathing
Old Sep 20, 2011 | 08:14 AM
  #229
aackshun's Avatar
After having all of the xfactors laid out in front of me... Hell it's going on the list, I can work around having a Q45 TB by fancy intake work. It's nice seeing everything laid out in front of you, instead of thinking of one or two things, I can think of about 4 ways to work it out if just making an adapter and bolting it up doesn't work.
False, you oversimplified it too much.
You know how the 370z makes most of it's power? Extremely little lift and very long duration.
It's a combination of a TON of xfactors here.... Which is why I'm open to my cam choices.
Old Sep 21, 2011 | 06:48 PM
  #230
MoncefA33's Avatar
There was an article somewhere about this in a magazine. I need to post it here.
Basically, a bolt-on DE 350Z made more power with JWT S1 cams than Tomeis, HKS, Brian Crowers, and a couple others...
Old Sep 21, 2011 | 06:55 PM
  #231
aackshun's Avatar
It really doesn't matter though, tooooo many different x factors to consider with cams, even with fooling the intake alone the results of that test could have been dramatically different.
Unless you are referring to another test that I am unaware of and they dyno'd each cam in different intake setups, and different exhaust setups to truly see what is the best cam....
Old Sep 21, 2011 | 07:15 PM
  #232
MoncefA33's Avatar
Chew on this for a minute.
http://www.modified.com/tech/modp-10...m/viewall.html
Old Sep 21, 2011 | 10:42 PM
  #233
aackshun's Avatar
Ooohhh yah, that was the one I was referring to, I was hoping there was another more conclusive cam comparison, but that one just won't do it for me. The only thing that article proves is the limitations of stock cams and that there's a good amount of power to be made.
Doesn't prove anything about which cam is better, it doesn't even have BC on the list which is among the favorite for all of the local shops who work on Z33's here.
Old Sep 25, 2011 | 10:32 PM
  #234
aackshun's Avatar
Well I WOULD be buying an Altima VQ35 this week... but ish happens.
I do get to goto KS again, that should be fun .
It should only be a two week set back, so hopefully in 2 weeks I should be in this position again and buying a 07-08 Altima 3.5 Motor.
Hell it's october... I don't need A/C.... I may just get the ECU... Osiris bypass, get a devil pedal and drop it in for Import faceoff.... Hrmm.....
Old Sep 27, 2011 | 10:17 PM
  #235
krazy6's Avatar
Do it! Should be pretty legit!
Old Oct 8, 2011 | 03:06 AM
  #236
aackshun's Avatar
All plans are off. I am pretty pissed @ how stupid I've been over the last week.
Next time you hear me talking about a VQ35 it will be under my hood though, but it won't be for a very, very long time.
Old Oct 8, 2011 | 07:04 AM
  #237
Crusher103's Avatar
No, the 370Z has control over lift aswell as duration. At high RPM guaranteed it increase lift by quite a bit.
Duration: Determines where you make power
Lift: How much power you make
11.6mm is actually max lift the VVEL can make, and that is quite a bit. It use that at high RPM, it also retards the cam timing at low RPM so the long duration produce more torque and lowers the lift so the engine does not seem rough. This has been done for a long time, if you look at the cams a stock VG30E has, its a 264/264 with like a 8mm lift. The loads of HP&TQ it made.
Old Oct 11, 2011 | 09:18 AM
  #238
aackshun's Avatar
..It use that at high RPM, it also retards the cam timing at low RPM so the long duration produce more torque and lowers the lift so the engine does not seem rough.
I have heard completely the opposite on how it makes it's power.
Even though the logic on cams is what I hear over and over again, that's not what I'm disagreeing with, it's how the Z achieves that TQ curve with Duration and but in this game there are MANY ways to accomplish the same thing... thus the reason why there have been so many motors and cars made since the Model T.
Old Nov 8, 2011 | 09:58 AM
  #239
aackshun's Avatar
Complete revamp:
02-03 Block
09 Maxima Pistons
.4 Cometic HG??
3.0L Timing+Electronics
Z33 Injectors
02-03 UIM
-NWP Block Off Plate
-Spacers from one of the two companies
Question:
How is it possible for the HR pistions to have clearance issues w/ the block when they are shorter than DE Pistons?? The rod lengths are the same for HR/DE/09 too... The 09 pistons appear (via FSM) to be even shorter... So now I'm really confused here
Also the cylinder block for the HR/DE are the same while the 09 is 20mm taller but with a shorter taper in section "a"
Old Nov 8, 2011 | 01:18 PM
  #240
SurraTT's Avatar
HR Swap Pioneer
I am disappointed
lol
GL with build man!!!
