Sponsored by:
Sponsored by: CARiD
6spd_Hayes - 2k2 Engine build thread
Old Jun 14, 2016 | 03:49 PM
  #41
6spd_Hayes's Avatar
Deluboz Cam Installation
New Timing Chain Tensioner
Rear Timing Cover Installed
Old Jun 14, 2016 | 03:50 PM
  #42
6spd_Hayes's Avatar
Timing Cover Population and Timing Chain Installation
O Ring Reinstallation
Old Jun 14, 2016 | 03:52 PM
  #43
6spd_Hayes's Avatar
Cleaned Oil Pan
New Rear Main Seal
Oil Pan Test Fit
Outer Timing Cover Reinstallation
Rear Main Seal Installation
Old Jun 14, 2016 | 03:53 PM
  #44
6spd_Hayes's Avatar
194080 Mile VQ35DE Before Removal
194080 Mile VQ35DE Removed
Old Jun 14, 2016 | 03:55 PM
  #45
6spd_Hayes's Avatar
And with that last post, any questions are welcomed....
Old Jun 15, 2016 | 03:21 PM
  #46
Mattx's Avatar
Excellent post. As far as the coolant passage for the hr head gasket, you did that yourself with a carbide dremel? It came fantastic. Very nice work.
Old Jun 15, 2016 | 10:51 PM
  #47
schmellyfart's Avatar
Fantastic threads. Keep up the good work!!
Old Jun 16, 2016 | 09:26 AM
  #48
6spd_Hayes's Avatar
I had originally planned on taking the block and putting it in a manual mil but my access to said mill dried up. I used a 1/4" air rotary file with carbide bits and did the final clean-up with a carbide Dremel bit. I made sure and taped everything up that I didn't want chips in and cleaned as I went. It turned out better than I thought it would.
For more information on this block modification, check out this link: http://www.jimwolftechnology.com/wol...BOLTS_juke.pdf
Since I do quite a bit of road course running, I figured it couldn't hurt to have a better cooling solution.
Old Jun 16, 2016 | 03:22 PM
  #49
Mattx's Avatar
Originally Posted by 6spd_Hayes
I had originally planned on taking the block and putting it in a manual mil but my access to said mill dried up. I used a 1/4" air rotary file with carbide bits and did the final clean-up with a carbide Dremel bit. I made sure and taped everything up that I didn't want chips in and cleaned as I went. It turned out better than I thought it would. For more information on this block modification, check out this link: http://www.jimwolftechnology.com/wol...BOLTS_juke.pdf Since I do quite a bit of road course running, I figured it couldn't hurt to have a better cooling solution.
Excellent thank you for the detailed info and thread. It's much appreciated.
Old Jun 25, 2016 | 09:23 PM
  #50
MoncefA33's Avatar
Very clean work. Love the S1 cams, had great experience with them in the past.
Old Oct 17, 2016 | 10:49 AM
  #51
Mike - Bromance Racing's Avatar
Do you have an estimate on the cost of parts for this rebuild? As well as a part list?
Old Nov 6, 2016 | 03:02 PM
  #52
L36's Avatar
L36
Would also like to see this.
Max139617
Oct 19, 2016 11:34 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
TheMafia
Sep 4, 2015 08:26 AM
