Factory deck power?
Old Jul 29, 2002 | 07:43 PM
releasedtruth's Avatar
rilla dope
Factory deck power?
Question. I looked for the stats everywhere, but I'd like to know what the factory power (watts per chan rms) stats are for the non-bose cd players in the 5th gen rides. I have some new speakers that need some power and I will amp them soon, but they will get sad factory power until then. Thanks
Old Jul 29, 2002 | 07:51 PM
maximadave's Avatar
detailerdaveb@gmail.com
about 8 watts per channel rms. Just make sure your replacement speakers are very effecient.
Dave
Old Jul 31, 2002 | 02:18 PM
95emeraldgxe's Avatar
whoa that totally sucks! - 8 watts dam
Old Aug 1, 2002 | 10:36 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Believe it or not, this is very true. Surprisingly most aftermarket radios are about equivelent. They all deliver about 15 watts per channel. What is stated on the box and what is true are two totally different things. It is not until you open the box, and maybe read a manual that you find the supposed 50W X 4 is only peak power, and even thats pushing it.
Look at it this way....you have a 4 channel amp (reputable company) that runs through say, a 25 amp fuse. Keep in mind this is JUST an amp.
Now you have a radio, which includes: Tuner/CD Player/motorized face/clock,volume,bass,treble,etc controls/ Different displays/remote control capabilities/ and supposedly a 200 watt amp (50X4). All of this from the same 25amp or most likely lower rating.
Just something to think about.
--Don
Old Aug 2, 2002 | 12:36 AM
nismo240sx's Avatar
iirc, mine had a 10 or 15 amp fuse
eric
Old Aug 2, 2002 | 08:15 AM
rilla dope
Indeed, high end components die under deck power. The Alpine deck I just purchased has the vdrive amp rated at 27w/rms per channel which is still weak for powering anything of substance and the distortion is much higher than a real amp. Larger heat sink, capacitors, resistors, you can't go wrong with an amp.
I'll be running 50w/rms true to the 4 speakers in the doors, that will at least give a little power to them.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
