Not enough bass!
Old Sep 2, 2002 | 02:17 AM
Shoooter_j's Avatar
Not enough bass!
I recently installed Infinity Kappa 652.5i's (6.75", 225 W max rating) in the front speakers and they seem to have as much bass as the crappy stockers (non-bose). I was wondering y this is...possibly due to the sh!tty JVC deck I have?
Old Sep 2, 2002 | 02:22 AM
mb1's Avatar
mb1
Re: Not enough bass!
probably...run an amplifier to them. Or if you want real bass, get like a 10in sub.
Old Sep 2, 2002 | 04:51 AM
wc91MaxSE's Avatar
Make sure the polarities on the speakers are hooked up correctly. If not, the bass from both speakers will cancel each other.
Old Sep 2, 2002 | 04:55 AM
d_warner's Avatar
Old Timer
Re: Re: Not enough bass!
The Kappas especially the oversize 6.5's are designed to go into a high quality sound system. Kappa is under the impression that you will be running some sort of mid-bass driver or sub with the smaller 6.5's. They intentionally focus the quality of the 6.5 in the mid bass area and highs. I have run many aftermarket (factory size) performance speakers, and I have never come across any that match the bass sound of the factories. The sound quality is much much better in all cases, but just not as loud. I would suggest running at least one 10" sub with your system. If you want to save a little trunk space, I would suggest the JL Audio 10W6. The new style has a removable/paintable trim ring (to match your exterior). The 10W6 also requires very little air space compared to most other 10 inch subs.
Old Sep 2, 2002 | 01:43 PM
Shoooter_j's Avatar
nice....thanx for the help dudes
I guess I was expecting more bass outta these kappas than they could possibly provide.
Old Sep 2, 2002 | 05:35 PM
ny96max's Avatar
probably cause you are underpowering them,hense all the distortion. They will blow out eventrually if you keep feeding them power from just your JVC. If i were you get an amp, youl be much happier!
Ant
Old Sep 2, 2002 | 09:09 PM
mb1's Avatar
mb1
this doesn't matter as much with door speakers as it does with subs.
Old Sep 2, 2002 | 09:39 PM
nissmax97se's Avatar
First off dude infity are really good check if the wirres all connected and second jvc suxs get new deck and u want bass where are your subs. that gives u all the bass in the world
Old Sep 2, 2002 | 11:17 PM
mb1's Avatar
mb1
Mar 12, 2020 12:06 AM
vybz05
Dec 10, 2015 07:38 PM
popdedop
Sep 11, 2015 11:17 AM
Cincy94Max
Feb 23, 2001 05:57 AM
Nick97SE
Dec 16, 2000 02:52 PM
