Install
Old Sep 27, 2002 | 07:36 PM
Rufus's Avatar
Install
can anyone help me install a bazooka sub with an amp? i heard that you have to hook it up to the back of the head unit but i have also heard that you can wire it straight to the rear speakers. by the way i have the stock bose in a 96 and the sub is going in the trunk.
thanx
Old Oct 1, 2002 | 09:06 AM
erty67's Avatar
Decal Specialist
Re: Install
thanx
you can hook it up to the bose system. All you gotta do is buy a line-level converter(like $20-30) and connect it to the wires going to the rear speaker. You will need to drop the amp down off the speaker to get the wires.
Old Oct 1, 2002 | 11:05 AM
dat_nomad's Avatar
Re: Re: Install
Actually the Bazooka Powered subs have high level inputs on them. I think if you get your connection after the Bose system amp (at the speaker) you should be fine. I could be wrong but I seem to recall this being the case. Fellas????
Old Oct 1, 2002 | 11:08 AM
dat_nomad's Avatar
Re: Re: Re: Install
No Actually you do need a line converter, I keep forgetting that d**n Bose system has to to be either bypassed or an adpter must be used. My bad
Old Oct 1, 2002 | 04:49 PM
erty67's Avatar
Decal Specialist
Re: Re: Re: Install
actually, I would try that. If the amp has high level inputs, it might work. I've never tried it myself. Just tap off the speaker, NOT the input of the amp.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
