Need your honest opinion
Old Oct 8, 2002 | 10:02 PM
Y2KMaxGXE-R's Avatar
what can my amp be used for? It is 2 channel 2x85=170rms @ 2ohm and 120rms @4ohm. I want it to run a single sub. What kind of a sub ??????
I also have Kappas all around, components up front and 2-ways in the back...My last resort would be to power the components..
Old Oct 8, 2002 | 10:47 PM
spuljack's Avatar
You could bridge the amp and run a JL W0.( if you want quality ) Or some cheap wall mart or sears sub. ( if you dont mind crap )
Old Oct 9, 2002 | 06:56 AM
jmax
If it were me I would try to get a quality sub that I would be happy with a couple years down the road. Then If I was able to save up some dough over the next 2, 6, or 12 months could get an amp to push it harder. Just go with a larger sealed or a ported box. Most subs will handle that amount of power in boxes that would otherwise make them prone to damage.
Old Oct 9, 2002 | 10:16 AM
I am trying to work with lower wattage, because not into big sound. Still, I am going to get one 12" instead of 10" or 8". SOmeone suggested that MTX 6000 will be good to use with my amp because of its low rating, might be on the look out for that...
I should be getting a new job soon...I guess I will just hold out for a few months and save some dough, get a stronger amp.
Old Oct 9, 2002 | 03:42 PM
jmax
Like I said, I wouldn't skimp on the sub. More power isn't just for greater output. The best use of greater power is better sound quality. Even if you were to build an SPL system, the SQ would benefit from greater power. Greater power yields better control of the speaker. But if you have a cruddy sounding speaker to begin with, greater power will just amplify the crud.
REDinLV
Aug 15, 2024 12:30 AM
05RLS2
Sep 27, 2015 09:24 PM
dvcamp
Sep 18, 2015 10:17 AM
ac max 92
Sep 17, 2015 07:35 AM
