doing my install NOW..need help PLEASE!!!
Old Apr 2, 2003 | 01:12 PM
celicafreek876's Avatar
just a few quick questions before I do my install..right now Im just waitin for UPS to deliver my AOEM-NIS2 kit..this is gonna be my first time doing it..I have a general idea on what to do..just to be on the safe side..once I get my AOEM-NIS2 kit will I know where it needs to be plugged into? can anyone give me a general description..I know where the power wire goes to..just need to know where the remote wire attaches to, does that attach to the HU itself or the AOEM-NIS2 kit?? and last but not least..the RCA cables..attach to the HU or AOEM-NIS2 kit?? doing my install today so any kind of help would do..thanx
Old Apr 2, 2003 | 02:33 PM
MetaOrbit's Avatar
Got Projectors?
Re: doing my install NOW..need help PLEASE!!!
You will know where to plug the kit into. On the back of the Head Unit, you'll see a set of plugs at the top. You will need to remove those (I found it easiest to remove them by prying them out from the bottom of the plugs) Once you do that, you plug the kit into the back of the HU, and the plugs you removed into the kit (If I remember correctly). It is real straightforward. The kit has four RCA leads coming off of it along with a remote wire. You can route these anywhere you wish. I would recommend running them out the right side of the console and running your RCAs down the right side of the car (especially if you ran your power wire down the left side of the car).
I think the hardest part was getting the vents out. It WILL take force. Just be sure to wrap whatever tools you use with cloth. I found it easier to remove the vent assembly by wedging it out from the sides.
Old Apr 2, 2003 | 03:29 PM
ok I FINALLY recieved my AOEM-NIS2 kit..just wanna clarify..there are 2 sets of RCA leads on one end..I only have to use one set of RCA leads to connect to the amp right??? and on the other end of the kit there are 2 sets of harness leads..which set do I use..One set consist of mostly red, orange, yellow, grey, black, white, and blue wires and the other set consists of green and purple...the set with the red, orange, etc.. has a tag on it that says ADD-NIS2..is that the that goes onto the back of the HU? what about the other wire harness connector where does that go to??
Old Apr 2, 2003 | 03:41 PM
MetaOrbit's Avatar
Got Projectors?
You only need to use one pair of RCA leads to hook up your amp. If your goal is a sub amp, you need to use the pair that are labeled "rear."
As far as which plugs go where, I can't remember exactly what everything looks like, but it's basically a matter of putting the plugs where they'll fit. Just remember the kit goes in between the Head Unit, and the wiring harness that originally plugged into the back of the HU.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
