Trunk Floor Board
Old Apr 17, 2003 | 07:41 PM
CaLSoNiC
Trunk Floor Board
Well, The crappy flexible POS that came with the car is all bend and concaves because of my subs. I was thinking of doing a hard floor in the trunk. I was just wondering what you guys had replaced it with. Im looking for something "light" yet strong.
At first I was gonna do some ply wood, then I rememberd how heavy that **** is. What about peg board or something like that?
All opinions welcome. Thanks.
Old Apr 17, 2003 | 08:41 PM
max'n out's Avatar
Ultra light mdf
Old Apr 17, 2003 | 08:58 PM
studman's Avatar
1/2" plywood will do the trick, but since you're installing subs, get the MDF. But if you are just needing something to make a flat floor over the spare tire, 1/2" plywood and a jig saw will do the trick
Old Apr 17, 2003 | 09:32 PM
max1ma97se's Avatar
3/4 mdf floor heavy as fiznuck but it dosent move up and down when i hit bumps and i can mount my amp securely on it
Old Apr 17, 2003 | 09:43 PM
CaLSoNiC
whats mdf?
Old Apr 17, 2003 | 11:07 PM
mb1's Avatar
mb1
I did plywood.
Old Apr 18, 2003 | 12:20 AM
Cumalittle
Originally posted by CaLSoNiC
whats mdf?
middle density fiber i think...this is type of board u build speaker boxes w/...
Old Apr 18, 2003 | 09:44 AM
largestal's Avatar
medium density fiberboard. A composite of glue and basically sawdust. When you cut and/or rout the stuff, the dust goes EVERYWHERE. Cut it outside.
It does not hold screws as good as plywood, but most sub boxes are not under as much stress as furniture, so when bos building use lots of glue and pre-drill and countersink your holes before screwing. This will keep the edges from splitting and the entry point of the screw from 'bulging'.
MDF does absord water easily but I have had great luck using WATCO penetrating oil to protect surfaces from water damage. Available at most woodworking stores and goes on easy and dries fast.
MDF is heavy stuff, but there is a lightweight version available. Check with your local lumber yard. Some Home Depot stores carry the light stuff, but not many.
Old Apr 18, 2003 | 04:48 PM
CaLSoNiC
Eh, I just picked up a 6'x8' piece of 1/2in Plywood. Only costed me $9. Gonna get choppin here in a couple of minutes.
Old Apr 19, 2003 | 08:01 AM
skeelo34's Avatar
pegboard bends. I have it for about a year, its starting to slowly lose its shape.
Old Apr 19, 2003 | 11:02 AM
maximamaybe's Avatar
Check out my homepage. Also here are a few pics. I used Half inch MDF.
2k2madmax's site
Old Apr 19, 2003 | 07:04 PM
JDM4LIFE's Avatar
i also wanted to replace this before mounting my subs. can you get it to be the size/fitment of the trunk floor and still fit it in the trunk or do you have to trim it down for it to fit?
Old Apr 19, 2003 | 09:37 PM
Mine fit in great. Especially after I cut it in half and put a hinge on it so that I can easily get to the spair. Remeber that the trunk is very uneven. Also cut larger so that you can trim down if needed. Another hint. I used the carpet mat to help. I was able to trace it and start trimming from there.
REDinLV
Aug 15, 2024 12:30 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
