Need help on a weak antenna signal after HU replacement
Old May 5, 2003 | 02:36 AM
foodog226's Avatar
I replaced my factory Bose HU with a Kenwoood DPX 6020 in my 98 maxima and everything is fine but the antenna signal is lower than what it was when I had the factory HU in. If anybody could help that would be great.
Old Aug 11, 2003 | 11:42 AM
NookieMax's Avatar
Re: Need help on a weak antenna signal after HU replacement
Hey man, I had the same problem with my 99 max installing a pretty f**ken sweet Pioneer HU. I was told maximas have two antennas. One power near the trunk and one wired in the back window. Thats why the factory antenna plug has two pins. If you used an antenna adaptor like I did, only one of the antennas get used. Set up the correct way I was using the weaker window antenna. I had to shave off the numb on my adaptor to in could switch it around. This resulted in recieving a much stronger signal from the power antenna. try it, worked for me.
Old Aug 11, 2003 | 02:19 PM
damon41978's Avatar
I have the JVC KDSH-99 and the signal is absolutely horrible, to the point, where there are only two words coming out every minute. I own the 2k1 Max. Can you explain in more detail what you did? Thanx.
Old Aug 11, 2003 | 02:57 PM
NookieMax's Avatar
ya, I'm not sure if its the same on the 2k1 max, and i know its different if you had the Bose system. the factory antenna plug has 2 "prongs" each represent one of the two antennas. Cheap antenna adaptors only use one antenna and "cut-out" the other one. If your adaptor is using the weak signal antenna, disconnect it, and turn it around so that the other "prong" is being used instead. You may have to snap off or shave the numbs, or guides on your antenna adaptor so you can reconnect it.
Old Aug 14, 2003 | 05:03 AM
POPO6SPD's Avatar
Hello guys,
I am experiencing some reception problems, but it occurs now that I have added and amp/sub to the factory Bose. I haven't checked the ant. plug again yet (PITA to remove the Bose HU) but my fm reception seems worse, kinda crackily. CD's play awesome. would the line level adapter have anything to do with this? or does it sound like my ant. plug is loose? thanks for the suggestions.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
boomerbrian
Sep 4, 2015 08:25 AM
