Problem with alarm system
Old Jun 4, 2003 | 12:34 AM
looney662's Avatar
I just installed an alarm on my 96. Everything works fine but the lock and unlock. I tap into the unlock and lock wires using relays but it doesn't work. I don't know what the problem is. Does anyone know how to wire it up? Atleast i got my trunk to open with my new alarm. It's a pain with a maxiam, compared to other cars!!!
Old Jun 4, 2003 | 03:25 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Where did you tap the lock and unlock wires? Why was a relay neccesary? They are both negative pulse, with unlock being douple negative pulse. Both found in the driver side door.
--Don
Old Jun 4, 2003 | 07:56 PM
ny96max's Avatar
you dont need relays for the unlock and lock wires... the wires you want are at the drivers switch and are 20-22 gauge.
also keep inmind the unlock for 95-99 is a double pulse(-). Make sure you set that feature on the programming of your alarm.
what brand/model alarm do you have? and are you using any kind of tech-soft?? if not i can e-mail you the colors tomorrow
Ant
Old Jun 5, 2003 | 09:43 AM
ny96max's Avatar
light green/red = power lock
green/yellow = power unlock
both at drivers switch panel.
goodluck!
Ant
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
