Rear view mirror falliing? What the heck are you guys running?
Old Jun 14, 2003 | 02:25 PM
Bmr4life's Avatar
Just wondering what kind of a system you guys got that makes your rear view mirror fall because mine only falls everynow and then and my ***** plenty loud. The rear view mirror in the max is one of the best i've yet to see when it comes to staying planted in bass cars.
Old Jun 14, 2003 | 02:55 PM
AscendantMax's Avatar
Re: Rear view mirror falliing? What the heck are you guys running?
dunno about other gens, but my 3rd gen's rear view mirror is mounted to the roof instead of the windshield. no falling-off problems here.
Old Jun 14, 2003 | 03:32 PM
Bmr4life's Avatar
oh, my fault. described it wrong. mine is attached to the roof too. What i meant was it tilting down real bad making you have to re-adjust it.
Old Jun 14, 2003 | 04:08 PM
Unibomber's Avatar
i have 2 kicker L7 12" with 2 kicker kx1200.1 amps
Old Jun 14, 2003 | 05:29 PM
Bmr4life's Avatar
how much trunk flex do you have because where the word M A X I M A is on my trunk moves in-out up-down like crazy and it sounds horrible.
Old Jun 15, 2003 | 01:23 AM
Unibomber's Avatar
i put expandable foam in the trunk and stuffed the other part of the lid with fiberglass from the walls of my old basement
Old Jun 15, 2003 | 10:53 AM
D1NOnly34's Avatar
I read the FAQ about the rear view mirror, but it didnt work for me, for my bass still makes my mirror go down, making me re-adjust alot. So what could I do, also, where did you get that expandabel foam? Price? Thanks
Old Jun 16, 2003 | 12:31 PM
Unibomber's Avatar
foam is at home depot in the insulation section
as for the mirror, if you look behind there is a screw. tighten it.
i also took off those 2 lights above the mirror and stuffed insulation all around there to lessen the vibration around the pole leading to the mirror
Old Jun 16, 2003 | 12:59 PM
D1NOnly34's Avatar
Good idea, I dont know about the screw but I'll check it out, also, what have you guys, especially those with sunroofs, done about the panel shaking to much? WHen I have my bass up and sunroof open, the panel vibrates a lot. ANy idea?
Old Jun 16, 2003 | 03:25 PM
Jr'sMaxima's Avatar
Make sure to tape stuff off in the trunk though when using the foam, as it can cause bad problems like making your trunk button not work, or even causing the turn lock to not work as well, lol. Trust me on this one.
My mirror doesnt move at all with my IDMAX pounding away. I guess its nice and tight in there cause trust me, this sub hits LOUD!
Old Jun 17, 2003 | 01:24 AM
raga55's Avatar
If you take out the rubber pole thing between the mirror and the windsheild and turn it upside down and turn it a little it stops the mirror from falling as much. I dont know if this will work in all 4th gens but it worked for me.
-Raga
Old Jun 17, 2003 | 03:00 PM
Unibomber's Avatar
dont even go near the rear part of the trunk lid with the foam
Old Jun 18, 2003 | 08:56 AM
hrygeek's Avatar
We installed an Orion HCCA 15 ported to 33hz in this car
http://www.cardomain.com/id/phatman5050
and I don't care what we tried, mirror points at shoes after about 10 seconds of music playing. No trunk rattles though. This guy actually broke his mirror (yes, broke it in half where it connects to the actual mirror).
http://maxima.cardomain.com/id/2k2kevpearlse
Old Jun 18, 2003 | 01:34 PM
quiksand's Avatar
I have one 12" L7 in a ported box being fed 1000 Watts from an Infinity Beta Digital Amplifier. Mirror moves like crazy.
Old Jun 18, 2003 | 07:33 PM
MaxinOutSE's Avatar
does that really work
Old Jun 19, 2003 | 06:59 PM
Unibomber's Avatar
very well actually
Old Jun 22, 2003 | 07:41 AM
mingo's Avatar
mine kept on tipping off with the pair of JL 12w6, and now i got a pair of JL10w7
Old Jun 22, 2003 | 07:47 AM
D1NOnly34's Avatar
Just a slight turn of the screw and now it doesnt fall anymore
Old Jun 22, 2003 | 07:52 AM
mingo's Avatar
EHHHHHHHHHHHHHH? you can tighten those??? i didn't see any screw heads or anything like that on my fifth gen mirror, they are just a series of ball and socket joints.
Old Jun 22, 2003 | 10:36 AM
D1NOnly34's Avatar
hmmm, the screw was on the back, just turn it around and see if you see a screw, I didnt know there ws one there until I read this post.
Old Jun 24, 2003 | 03:02 AM
mingo's Avatar
thanx for the heads up.. i'll go tighten mine up whenever i hook up the subs..
JRod28
Feb 4, 2016 11:07 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
4 door GT-R
Aug 22, 2015 07:50 AM
BobMax
Aug 19, 2015 04:39 PM
