Alpine CDA-7889 Has No Amp?
Maxima owner since 2000
Alpine CDA-7998 Has No Amp?
I would like to buy the CDA-7998, but it says it has no internal component amp. the one model below this one does have an amp. what does this mean? is it talking about a small amp that fits in the head unit? i have a 1500 watt MTX amp, but that's not it right? thanks in advance.
Originally posted by chinaonnitrous1
Duh vinh...like most headunits list 50x4 60x4 etc...this model has all the RCA outputs to use an Outboard amp.
i must have the lery syndrome or something... hm... gotta get that checked.
seriously though, i'm confused.
To put it simple.. Most radio have a small built-in amp that would provide maybe 40 to 60 watts to each channel.. But the model you mentioned has no internal amp.. Meaning it will send out an audio signal, but it is your job to amplify it.. To do this you have to buy an amp, like mentioned above either 2 or 4 channels.. Hope this helps..
Originally posted by lwebb12
yes the 7998 has three outputs. front rear sub. you should buy a 4 channel amp to run the speakers in your car and hook the sub output to you sub amp
Kyle Lee Cleveland
09-28-2015 07:58 AM
popdedop
09-11-2015 11:17 AM
