Potentially using higher RMS than speaker supposedly can handle
Old Sep 25, 2003 | 07:26 PM
GarthG's Avatar
I have MB Quart Mobile 160.30 kx (4 or 5 years old) and with my old set up I was running a PPI PC4400 amp to power the front and rear speakers (potentially 50W RMS to each). Well today I decided to bridge the front speakers and hook the rears up to the deck. While I think the sound is much improved with the higher power (Potentially 100W RMS) I am concerned because the peak power handling of the speakers is 85W. I know that they can get too hot if played at high volumes, but do I have to worry about extended playing time even at normal volumes? Also does anyone think I will have any issues running this setup? Any help is appreciated.
Summary:
-Running 100W RMS to a speaker that has a peak power handling of 85 RMS, bad at normal volumes for long periods?
-Anyone advise against this? If so, reasons?
Old Sep 26, 2003 | 09:12 AM
Maxima Dan's Avatar
I really wouldn't worry about burning out the voice coil, you will over extend the mid before that. If you hear it bottoming out, turn the volume down. That said, I have always run my front end with 125W RMS per channel and have only torn the surround on one speaker. Oh yeah, I broke the tinsel lead off another. But that was more a freak accident and a moment of stupidity. Bottom line is that if you are careful you shouldn't have any problems.
Old Sep 26, 2003 | 12:51 PM
soundmike's Avatar
Very sound, Mike
From what i learned, it's better to have an amp that's powered higher than your speaker can handle.
Why? Because if your amp is of so-so quality, there's a good chance your speakers will clip and that's a bad thing.
Old Sep 27, 2003 | 09:59 AM
TAPOUT's Avatar
You will lose
You will be fine....You have the blessings of the Audio Gods. Just remember to set up the crossover.
Old Sep 27, 2003 | 02:18 PM
GarthG's Avatar
I made sure the crossover is set up correctly. . . And it has protection circuitry for the tweeter. . . I am typically careful with my system and never have seen just how loud it can go, but I figure that as long as I don't push the mids too hard, and pay attention if the circuitry protects the tweeter, then I will be fine. Thanks for all your guy's help.
Old Sep 29, 2003 | 05:37 PM
gtbigup's Avatar
You should be fine just dont turn your system up too loud.If you start to hear distortion you're too loud and stand a chance of burning up the voice coil.The 15 watt rms is not a big deal though
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
