amplifier 2 subz,,,,?
Old Oct 27, 2003 | 10:36 PM
XeroX's Avatar
Hella internets
i want to hook up an amp to my 2 12"s in the trunk,.....i saw in the how 2s, how to do it, but can i really just tap into the speaker lines for the 6x9s in the back? does it sound just as good?
I wana try it but the instructions dont have pics and i kinda dont get it lol
can anyone clarify?
Old Oct 27, 2003 | 11:08 PM
KsuMax's Avatar
Cheesing away...
When I hooked up my amp, you have to run wires from your headunit. I'm confused about taping into the speakers. We don't have 6x9's. We have 6.5" speakers. But for powering the amp, you have to get it from the battery and drill through the firewall and run the cable to your trunk or where ever you are placing the amp.
Old Oct 27, 2003 | 11:40 PM
XeroX's Avatar
Hella internets
Are there detailed instructions on how to do it?
Old Oct 27, 2003 | 11:57 PM
Bmr4life's Avatar
you can splice the rear speaker wires and run them to your amp if it has speaker level line-in inputs, otherwise you'll have to get a line-in to rca convetor (assuming you don't already have an aftermarket headunit that has rca outputs). Either way you're going to have to run a power wire from the positive terminal of the battery to the positive connector on the amp and also find a good spot for a ground in the trunk or rear seat area that will then be connected to the ground on the amp. You would also have to deal with the remote wire hook up which would be avoided if you get an amp with the speaker level input or have a HU that has the remote line output.
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
http://www.caraudioforum.com/
http://forum.sounddomain.com/
http://www.jlaudio.com/tutorials/index.html
http://www.installdr.com/
and there are many more in the Audio Forum FAQ
sliptap
Sep 30, 2015 05:57 AM
EdRomo86
Sep 12, 2015 07:49 PM
thenewguyy
Sep 12, 2015 11:12 AM
kirkhilles
Aug 8, 2015 10:53 AM
Maxima95GLE
Dec 7, 2000 11:02 AM
