2-ch vs Mono amp? Help!!!
Old Nov 7, 2003 | 03:36 PM
esc92's Avatar
Hi guys...still working on the system.
I was looking into getting a 800 watt Audiobahn amp to power two 10" (here's the site http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3056456033 ) subs. Which amp (2channel amp vs. Mono D amp) would be better for those speakers?
Old Nov 8, 2003 | 06:40 AM
-Red-'s Avatar
Class D is a more efficient amp. It has less of an amp draw, which means it will be easier on your alternator. You have to be careful in matching the power the amp puts out with the impedance of the subs. A lot of the class D amps will put out the most power at either 1 or 2 ohms, so be sure your subs can be wired for that setup.
Old Nov 8, 2003 | 06:41 PM
esc92's Avatar
The subs that i'm interested in ( http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3056456033 ) are at 3ohm or 6ohm operation. How do I set up lets say two of these speakers to a Mono D amp? I was looking into a JBL 600.1D amp. I'm really on a budget. Can anyone help?
Old Nov 8, 2003 | 07:24 PM
AscendantMax's Avatar
if you're going the mono amp route, make sure the amp can take levels below 2 ohms. Since each sub is DVC 6 ohms, you can wired them into parallel. once wired in parallel, your amp will see 1.5 ohm load. most amps are stable down to 2 and a few down to 1. i believe that JBL amp isn't stable below 2 ohms.
Old Nov 9, 2003 | 10:01 AM
Maxstilln's Avatar
The JBL amp is 1 ohm stable however there is no increase in power output, and its of the only amps at that price that is 1 ohm stable! Not to mention that it is a much better sounding amp then the Audiobahn and its has a much better build quality. I had 2 BP1200.1s, 2P180.2s and an P80.4 in my max, now I'm upgrading to the new JBL amps.
Old Nov 12, 2003 | 09:00 AM
jmax
Yeah, the JBL should be fine with a pair of the dual 6 ohm subs wired parallel.
Old Nov 12, 2003 | 05:07 PM
esc92's Avatar
Well I was able to get a hold of 2 JL 10W3 D4 and I'm putting them in a sealed box. I was looking at the JBL 600.1 mono amp. Will that amp be good enough to handle those subs at high volumes? And how should I connect them? What's the difference from connecting speakers in a series or parallel?
Old Nov 12, 2003 | 05:14 PM
http://www.justwoofers.com/Tech/Wiring/Main.htm
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
