Show Us Whats In Your Trunk...
Old Nov 7, 2004 | 06:47 PM
  #441
2 Da Max's Avatar
my bad let me repost
yes that shiit pumps
Old Nov 7, 2004 | 10:03 PM
  #442
1phtmax's Avatar
Originally Posted by nismos14
very nice setup 1phtmax too bad no spare haha jk
im working on where to put the spare
Old Nov 8, 2004 | 09:39 PM
  #443
pedroboe's Avatar
Originally Posted by Broaner
Pedroboe, I like the idea of mounting the amp. I'm a bit biased though because I used to have mine setup like that. It may be a good way to secure the amp but it can be very bad for depending on the power output. The amps' heat sincs are designed to be upright. Being up-side-down greatly reduces the thermal efficiency of the fins and thus can cause overheating. That said, it doesn't look like an extremely powerful amp so you don't have much to worry about. BTW, just informing you, not picking on or anything. I did the exact same thing just a year ago. I had no idea it was bad until a local radio shop made fun of me.
Thanks broaner, I'll look into that.
Old Nov 10, 2004 | 09:19 PM
  #444
generation3's Avatar
I will have more pics up this weekend for now this is my only one. I have pics of my wiring up in the Audio & Electronics Section under fuse? It looks nice I think Tweeter did a good job.
Old Nov 14, 2004 | 07:15 PM
  #445
whats behind the great wall
Pics of subs as promised
Pic of the switch that turns subs on or off
Old Nov 14, 2004 | 07:18 PM
  #446
ps: tape is marking where the wall is and i just moved some stuff so people can see and because normally the subs point straight up makes the rear deck rattle like no other im testing how i want the subs positioned
Old Nov 15, 2004 | 05:49 AM
  #447
nismos14's Avatar
§è~® f®ÈÄk
is there a speaker mounted in the pass through too? whats that all about? pics?
Old Nov 15, 2004 | 05:51 AM
  #448
nismos14's Avatar
§è~® f®ÈÄk
generation how does the wall mount in? is it screwed in? or does it just push in
Old Nov 15, 2004 | 09:27 AM
  #449
there are 2 screws which go into the rear deck and there are 8 screws that go into the box the box is normally vertical i'll post pics of that tonight if i can
Old Nov 15, 2004 | 08:14 PM
  #450
Igor911's Avatar
So far I think on this board, only 2 members have nice trunks (in maximas)....
Polo and RVD, correct?
Old Nov 15, 2004 | 09:39 PM
  #451
MacAlert's Avatar
You forgot Jairo(Playero).
Old Nov 15, 2004 | 10:00 PM
  #452
Igor911's Avatar
hmmm...I didn't forget him, he is on the fence with me.
Old Nov 16, 2004 | 08:14 AM
  #453
Conrad283's Avatar
I need a truck
Just because he's on the fence with you doesn't mean you can't give him credit.
Jason's trunk was sweet and so was shavedmax's
Old Nov 17, 2004 | 12:03 PM
  #454
DR-Max's Avatar
Pedroboe,
I was planning on installing the amp the way you did it. But I thought that installing an amp upside down isn't recommended because the heatsinks should always face up as heat rises to the top and is dissipated. Unless your amp is self-cooled by an internal fan.
Anyhow, mine is very simple and very audibly suitable. One sub located at the driver side corner of the back of the trunk firing towards the opposite side (passengerside). I could have sworn that the RF HX2 10" (DVC) sub bumps like my JL15w3 sub at 50hz and below. It's loud enough for me. BTW, the Brahmas are insane!!! I wouldn't be able to stand it either for a long time.
Pics:
http://www.cardomain.com/member_page...87_43_full.jpg
http://www.cardomain.com/member_page...87_44_full.jpg
I've been playing with the subwoofer placement that is why the trunk panels are still missing when the photos were taken. I still have full use of the trunk.
Old Nov 18, 2004 | 05:23 AM
  #455
nismos14's Avatar
§è~® f®ÈÄk
Originally Posted by 2DaMax
Pedroboe,
Pics:
isn't it great how that one speaker pounds so hard? i just got one too and i have it in a tiny box about .55 cubes and i layed it flat on its back in the same spot as ur's but the sub is facing up and it pounds. To me it sounds even better than my old solo baric 15 sounded, its a very very nice and convenient setup since i also can still use my entire trunk, pics will be around soon!
Old Nov 18, 2004 | 10:15 AM
  #456
DR-Max's Avatar
Hey......another HX2 brutha!!!
Yep, speaker placement is key for small subs. I tried your setup (same location as mine) and I got more punchiness in my bass having the sub fire up towards the trunk lid. Then I had it fire forward (towards the seats), I got the same result but with a bit of deepness. Still, I prefer the sub facing the passengerside wall of the trunk. Plenty of deep bass!!! I guess it all depends on the type of music you listen to. I listen to mainly hip/hop, trance, house that's why I wanted deeper bass. The sub is crossed at 80hz which suites me best. The enclosure has an internal volume of .75 cubes.
The only thing I gotta get now is a grille to protect the cone from getting pierced by objects in my trunk. Getting a grille for these subs isn't easy. I might have to get it custom made. The RF grille is about $30, and they're not even sure if the cone will hit it at long excursions.
Old Nov 18, 2004 | 11:21 AM
  #457
C MAX's Avatar
I wanted deeper bass. The sub is crossed at 80hz which suites me best. .
2DaMAX have you tried 45hz. 80hz is a general crossover point but for hip hop 45hz is earth quaking. i produce hip hop and mixing is my specialty and i love deep clean bass and 45hz has proven worthy to me. what are your mid crossover points.
Old Nov 18, 2004 | 11:43 AM
  #458
DR-Max's Avatar
My system doesn't have an outboard active crossover unit. Everything is done thru the h/u's crossover section, plus the passive crossover network that comes with the Kappa Perfect component sets. The h/u's filtering capability is pretty limited but it serves my purpose enough. For bass, I usually switch back and forth from 80 - 50hz (lowest setting for sub). Most of the time, 80hz cuts it for me. I'm not trying to play for people outside my car. I like to keep things inside so that I can hear my music and feel the bass w/o drawing attention from cops a block away from me. I've done all that back in my early 20's and I'm pretty much done with that phase. The h/u's high-pass filter is set to 125hz (highest setting). Then I compensate that thru the built-in parametric eq of the h/u's midrange section. I can attenuate 125hz a bit since that might be too much for the mids to take, and bring up some at the 200hz range and so on. I get good sound out of this old Pioneer h/u , its all based on individual preferences. Some people like to tweek things to the T and they require more components to do so. I'm just keeping things simple.
Old Nov 18, 2004 | 12:07 PM
  #459
C MAX's Avatar
50 hz is fine also. and like you i dont play for the block either. i have over 300lbs of dynamat in the car and the bass stays inside just the way i like it. but you said you like your bass deep 45hz is deep not loud. like i stated im a engineer so i do have the tendency to get critical with tuning but it sounds like you know what your talking about and i love pioneer best product for the money.
Old Nov 18, 2004 | 12:25 PM
  #460
DR-Max's Avatar
Thanks for the input. Yes you are right, when I switch down to 50hz, I get sick deep bass!!!
Old Nov 18, 2004 | 12:31 PM
  #461
C MAX's Avatar
its funny my younger brother use to wonder why i always change things up and after i do it he realizes, its not about loud its about frequencies. 50hz is the best setting for a low note. i too am getting to old for the bang bang been there done that but quality sound i would take any day. that speaker you have looks like it could hit some pretty decent notes.
Old Nov 18, 2004 | 12:40 PM
  #462
DR-Max's Avatar
Oh yea it does....I popped in a Crystal Method cd right after installing the sub. I know my sub sounds right when I like the bass notes coming from it when playing that cd. If the 10's does this, I can only imagine what the 12's can do.
Old Nov 18, 2004 | 04:25 PM
  #463
Ant96GLE's Avatar
CMAX you havent told us what your new setup is going to be
Old Nov 18, 2004 | 04:49 PM
  #464
AscendantMax's Avatar
Gotta love the Brahmas
Old Nov 18, 2004 | 06:43 PM
  #465
Playero's Avatar
Sanduguero
Can you post your set up.... I have not seen any pictures
Old Nov 18, 2004 | 06:47 PM
  #466
Playero's Avatar
Sanduguero
Conrad coming up in March I am ripping the whole trunk apart with a New Setup!!! Let see if he feels am on the fence with him still ....
I am getting ready for summer again.....
No flame intended Igor
Old Nov 18, 2004 | 07:13 PM
  #467
DR-Max's Avatar
You all can let me know when you tear up yer trunks, if you have any surplus amps or subs in good condition. I'm getting a new SUV next spring!
Old Nov 18, 2004 | 08:29 PM
  #468
Igor911's Avatar
You want pics, eh? I'm not showing any pics untill its 101% finished...about another month or so.
Just off the top of my head, im gonna have about 36 12" Cold Cathode tubes in the whole setup...
and I wasn't flaming u, i was talking about ppl who have trunks that make u say "wow". I'm entitled to my own opinion.
What are u planning to redo in your setup?
Old Nov 19, 2004 | 05:00 AM
  #469
nismos14's Avatar
§è~® f®ÈÄk
and i have a pioneer head unit too lol i have mine crossed over a bit higher because i also listen to all sorts of different music and it suits me perfectly!
Old Nov 19, 2004 | 06:21 AM
  #470
C MAX's Avatar
what up ant. right now i picked up the alpine V12 4 channel for the mids and highs, and im gonna go with 2 12 in L7 kickers with either the arc 900.1 or the zapco 850 watt amp and another lighting cap 1 farad for the subs. i still have the alpine deck and electronic crossover which they didnt get. im gonna go back with the infinity kappa perfects for the mids and highs and then have it custom built into the trunk like before. the car is in the body shop right now so maybe by next week i can begin the work. hows your system holding up.
Old Nov 19, 2004 | 06:57 AM
  #471
MannyNJ2k2max's Avatar
I hope its sounds good, trunks that say 'wow' and sounds like shyt are for the birds...
Old Nov 19, 2004 | 07:20 AM
  #472
I didn't know Polo's trunk was finished......
Old Nov 19, 2004 | 08:45 AM
  #473
MacAlert's Avatar
Polo's trunk will never be finished....
Old Nov 19, 2004 | 09:54 AM
  #474
Pearl96Max's Avatar
I tend to get a bit irritable
On the fence? I surely hope you talking about Strictly looks rather than products......
--Don
Old Nov 19, 2004 | 10:09 AM
  #475
Igor911's Avatar
--Don
Yes, looks.
I'll quote myself
Old Nov 19, 2004 | 12:25 PM
  #476
pedroboe's Avatar
Pedroboe,
Pics:
Thanks for the Tip 2DAMAX, I'm gonna try the same setup you have.
Old Nov 19, 2004 | 09:42 PM
  #477
Playero's Avatar
Sanduguero
Something Different and louder! Hopefuly I wont have a new car by then...if I get a good deal on a G35 then the project goes straight to the garbage.....
Old Nov 19, 2004 | 09:44 PM
  #478
Maxima Dan's Avatar
WTF is a 12" cold cathode tube! I've never heard of a tube rated by length. Also any car amp is a hybrid tube amp that uses a solid state final output stage. The tubes are only 2-3 inches long.
I think there are a few trunks on here that sound a hell of a lot better than the two that you mentioned. Mine included, but I'm not showin' any pics. Last thing I need is some idiot jacking my stuff.
Old Nov 19, 2004 | 10:09 PM
  #479
Igor911's Avatar
wtf are u talking about?
Try google for "cold cathode"...and I'm sure someone is dying to copy off of your trunk.
Old Nov 20, 2004 | 11:21 AM
  #480
Maxima Dan's Avatar
You should have just called them Neons, when I think of tubes as they relate to audio I'm thinking of this: http://store1.yimg.com/I/yhst-847648...0_1820_6475984
Now if you could put a dozen of those in your trunk it would be much cooler than some crappy neon.
And yeah, I'm not posting pics because I'm worried someone will copy me. I could care less about that, just don't want anyone actually stealing my stuff.
