Mounting an Amp.........
Old Feb 24, 2001 | 12:58 PM
SilverBullet98's Avatar
Can you/is it a good idea, to mount an amp on the top or side of your sub box..... I was just wondering b/c I am going to be getting another small amp and I need a mounting location........
Old Feb 24, 2001 | 02:46 PM
CanuckAMP's Avatar
Not a problem at all. Only thing I'd be concernesd with is applying a little silicone or glue to the mounting screws to make sure you box doesn't leak through the mounting screw holes.
Old Feb 25, 2001 | 04:19 PM
94SUPERMAX's Avatar
It's a good idea. Just make sure the box and amp fit in the trunk the amp may get damaged when you push it back in.
Old Feb 26, 2001 | 09:24 PM
Matt93SE's Avatar
STFU n00b!
One other thing to beware of is cooling.. if you mount the amp on top of your sub box, just make sure there's enough air movement (or clearance) above the amp to give it enough airflow to cool properly.
Old Feb 28, 2001 | 06:18 AM
BRIGBOY's Avatar
Yah but if I get in your trunk..........
Then I can just rip out your box and walllah, I got your amps too. Thanks for making it easy on me.
I would never do that, but it gives effect to the story.
You should at least disconnect the trunk release near your seat and just use the key. So if the thief breaks a window he still cant get in the trunk, so easily anyway.
Old Feb 28, 2001 | 06:56 AM
CanuckAMP's Avatar
Not if the sub box is bolted to the body of the car
And if he uses security screws to mount the amps on the box he'll be keeping his stuff for a long time.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
