putting subs back in tomorrow.
Old Nov 27, 2003 | 08:53 PM
sk24iam's Avatar
I'm planning on reodin my trunk. I'm going to mount an amp opn each side of the trunk closest to the rear. I guess the best way is to mount a piece of mdf behind the carpet to the metal and then the amp to the mdf. I'm also going to mount my 2 subs as clsoe to the ski hatch as possible. To mount them with l brackets, can I drill down into the metal or should i put mdf under the carpet?
Old Nov 27, 2003 | 08:54 PM
nismos14's Avatar
§è~® f®ÈÄk
i would put mdf, but im not sure what does everyone else think? im interested to know also
Old Nov 28, 2003 | 10:31 PM
sk24iam's Avatar
I don't have a good drill that will go though metal so I think I will puncter a hole with a nail first. Also, my jack is going to be un accessable isn't it?
Old Nov 29, 2003 | 10:37 PM
nismos14's Avatar
§è~® f®ÈÄk
yup u wont be able to use ur jack
Old Nov 30, 2003 | 08:55 PM
Cliff Clavin's Avatar
Way out West
I would steer away from the jack side. As soon as you take the jack out or cover it up you will probably get a flat out in the middle of nowhere!
I don't know about the 4th gen, but on my 3rd gen, I mounted my amp on the side and do not have any access problems (I can still change my tail lights).
I know it's hard to see, but I drilled into the inner wall on the RH side and I put screws into the metal bracket on the LH side.
Good luck
JRod28
Dec 29, 2023 09:56 PM
vybz05
Dec 10, 2015 07:38 PM
kingw323
20
Oct 21, 2015 08:36 AM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
