Help me install basslink
Old Dec 24, 2003 | 03:15 PM
Sqard's Avatar
Alright, so I just bought a basslink, and im confused on how to install it. The amp wiring kit I bought comes with 8 awg power wire(w/ fuse holder), remote wire, a set of RCA cables(2 plugs on each side), and a ground wire. The power wire was pretty self-explanitory, ran it from the positive side of the battery to the trunk(for now). The ground wire should be simple also(any specifically good ground points in the trunk?).
Then I looked at the back of the bose head unit. There's only 2 plugs in the back. What do I do with the remote wire and RCA's? Someone told me I had to cut one end off the RCA's and splice them somewhere....do i need to do that with the remote wire also?
The basslink also comes with Universal Interface plugs. Is this instead of the RCA's? Will it sound better with the RCA's since I already have them?
Old Dec 24, 2003 | 03:40 PM
harrymay's Avatar
the remote trun on is pretty easy, i just spliced mine into the rear speakers and used that. is there a line level input on the amp, or is it just rca's. my kenwood amp came with both. you can also splice the line input into the rear speakers too.
Old Dec 24, 2003 | 04:17 PM
Sqard's Avatar
On the basslink it says Line Level Input right where the RCA jacks go....is that the same thing? Below that it has things that say Universal Interface.
Old Dec 24, 2003 | 04:20 PM
Sqard's Avatar
btw, i have the RCA's and remote wire wired up by the headunit already since someone said it was better to splice closer to the head unit
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
