Put a new head unit in and now my antenna always stays up, help!
Old 12-31-2003 | 08:35 AM
WillMax95's Avatar
I installed a Kenwood Exceleon x-869 head unit and now whenever my car is on, my antenna goes up, i only want it to go up when the radio is on, not when im listening to a cd. anyone know how to fix this?
Old 12-31-2003 | 08:58 AM
spreenyk888's Avatar
i had that problem when i had my pioneer radio in. now i just changed my radio to the sony xplod, and it doesnt do that anymore. i guess different headunits do that
Old 12-31-2003 | 11:00 AM
MIXXMAX's Avatar
The antenna will always stay up whenever the headunit is on. This is common in most aftermarket stereos. The only way around this is if the headunit has a separate lead for the ANTENNA control (not, mistakingly the remote turn on). Another way is to install a toggle switch in the power lead of the antenna to turn on the antenna on and off as you wish.
Old 12-31-2003 | 11:06 AM
MIXXMAX's Avatar
Being that your Kenwood is a higher end model, there should be a lead for the antenna control. I have owned alot of Kenwood headunits (top models) and most of them have a seperate lead for the power antenna control lead. Check your harness again, you had probably bypassed this. If I am not mistaken, I believe the color is a blue wire with a colored tracer. (The other blue wire is for the remote turn on---no tracer.) I hope this helps you out any.
Old 12-31-2003 | 06:57 PM
WillMax95's Avatar
thanx mixxmax. i think mine is the 2nd highest exceleon they make so its bad ***, ill check it out, thanx man
sctludwig
09-01-2022 02:32 PM
dvcamp
09-18-2015 11:17 AM
Maxima30
09-07-2015 07:13 PM
crazyespn
09-03-2015 02:30 PM
Justin Kroll
09-02-2015 12:06 PM
