aarrgghh - sub install help
Old Jan 6, 2004 | 04:31 PM
das's Avatar
das
hey all,
now, first off, I'm lame w/audio stuff, but here goes. the max I bought already had an amp, and sub/box installed. the other day the sub dies, so I order a new sub online. it arrives today and I go to install, thinking, ok take the 2 wires already in the box from the amp and plug into the sub. easy, right?
well, the apline diagram to wire has the 2 amp wires going to the positive and neg on the sub, but there are a pair of pos/negs on the sub. there is what seems to be a wire bridging the other set of pos/neg. do I need to bridge these, or can I just wire the amp to the pos/neg pair and leave the other sub pair open??
does that make any sense at all? please help!
thanks,
das
Old Jan 6, 2004 | 06:35 PM
Cliff Clavin's Avatar
Way out West
It sounds like you have a DVC (dual voice coil) sub.
http://www.justwoofers.com/Tech/Wiring/Main.htm
Check this out to see how you want to wire it. There are some options available, but it depends on your amp. There are others here that can help you more.
What was wrong with your old sub? Normally they don't "die."
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
