Subwoofer died out of no where...No more midjets in the trunk rassling.
Old Feb 11, 2004 | 02:30 PM
JetBlack SE's Avatar
Subwoofer died out of no where...Narrowing the Problem Down :)!
Hey guys I ran into this terrible mess. Out of no where My sub died on me once I started the car today. I was listening to it fine, and next time I started the car (5 min later) the sub never worked. I have the following set up
Pioneer 8500 Head Unit
Kicker L5 12" 1200 Watt
Phionex Digitl 2 Ch. 1200 Watt
Pioneer Speakers all around
Compacitator
Circuit Breaker
I checked every single wire from the ground wire to the power wire connecting to the battery.
Any thoughts or ideas?
P.S. Amp shows green light (no problems, and compacitator shows stead power flow.
Thanks in advance.
Old Feb 11, 2004 | 02:39 PM
Wisky97SE's Avatar
This happened to me a couple times (I also have the 8500 head unit, its great). . . but for me I just blew the fuse on the amp.
Old Feb 11, 2004 | 02:45 PM
KsuMax's Avatar
Cheesing away...
You'll get more responces in the audio forum
Old Feb 11, 2004 | 02:50 PM
if the mods dont mind please keep this open in this forum... I know there are a couple of audio experts here. Thanks
Ill also post this in the audio forum.
Old Feb 11, 2004 | 05:05 PM
Gates's Avatar
If your amp is showing the green light, then it is obviously getting power. Re-check all your cables, specifically the speaker wire from the amp to the sub and also the RCA cables on the amp. If the light for the amp is on, it is not going to be your power/ground wires or your fuses. If it is a wiring problem it has to be the RCA wires from the HU to the amp, the speaker wire from the amp to the box, or the speaker wire from the inside of the box to the sub. Is it possible that you blew your sub? When you last had it on were you running it very hard? If you still can't figure it out, it is probably best to take it to an audio shop.
Old Feb 11, 2004 | 05:16 PM
Highly doubt any chance on blowing the sub. I had it for about 4 months and never went above 35 out 50 max volume and no max bass boost.
Old Feb 11, 2004 | 06:23 PM
Mad Dhan's Avatar
i like ur title
i dont really know what to say without being there, try having someone else look over it, it might be something simple that got overlooked.
Old Feb 11, 2004 | 06:40 PM
TAPOUT's Avatar
You will lose
Disconnect the speaker leads from the amp, and see if you can "pop" the sub with a AA battery. If it does not "pop", you need to pull the sub out of the box, and see if it is disconnected in the box.
Old Feb 11, 2004 | 07:09 PM
I have taken the sub out of the box, however, no disconnected wires appeared. I will try the AA battery test. How do i go about it... touch one wire to the + and the other to the - ?
thanks
Old Feb 11, 2004 | 07:28 PM
I just went outside (WOW ITS FREEZING) and "poped the sub with the AA battery" it works, meaning that its not the speaker wire from the sub to the amp...
any ideas on my next move...
Old Feb 11, 2004 | 08:45 PM
bigtimber's Avatar
check the remote turn on wire coming from the back of the HU. I think its blue/white. if this wire is undone, the amp will still be getting power, but it wont turn on.
i think you can test this by jumping the +12v terminal with the remote terminal on the back of the amp.
Old Feb 11, 2004 | 08:49 PM
Thats the thing... my amp is gettin power thus its on and the compacitor is feeding it properly.. also its showing green status meaning its gettin full needed power and grounding.
Old Feb 11, 2004 | 09:19 PM
bigtimber's Avatar
i dont know the specifics of your amp, but on mine that green light just represents that the amp is getting power. There is a seperate red light that shows when it is on. Is this the case with yours?
You could also check if your HU is still configured for the subwoofers. If that got reset the same thing would be happening.'
good luck
Old Feb 12, 2004 | 05:43 AM
C MAX's Avatar
check to see if your getting output from your rca jacks from your sub.. maybe you hit a button on your h.u. and shut it off. also see if you can reset your amp..
Old Feb 12, 2004 | 09:24 AM
PROBLEM SOLVED!!!
THE GUY WHO DID MY INSTALL WAS A COMPLETE A$$!!
He ran the rca from the amp to the HU well untill the passanger side where it stuck out by the floormat, so someone in my car pulled it with thier feet and disconnected it from the HU, i opened the entire console connected it and taped it as a precaution, and then tugged the rca where it was showing away. Everything works fine, and now EVEN better, since I rewired every single wire..
Pheew!
Thank you guys VERY much for all of your help, I really appreciate it.
REDinLV
Aug 15, 2024 12:30 AM
maxima297
Sep 30, 2015 03:32 PM
sliptap
Sep 30, 2015 05:57 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
