5 channel Amp question
Old Feb 11, 2004 | 04:03 PM
crazymax's Avatar
Hello I have 5 channel amp..and I was told if I run the front mids, tweets, and rear speaker off 1 channel..same on the right side (using one channel for front and rear), and one separate for the sub that it would be better then running each speaker to each channel..no front and rear fade thou..and 2 channels won't be used..
Does that make sense, they said it would be more wattage?
I am running Polk audio mids tweets, and 6 1/2 in rear..and one JL audio 12 for the subwoofer..
Thanks in advance..
Old Feb 11, 2004 | 07:25 PM
JAIMECBR900's Avatar
What amp do you have?
I doubt that it could handle the drop in resistance. If you wire 2 sets of spkrs to each channel, you will see a 2 ohm mono or 1 ohm stereo load. Not many amps can handle that for long. Yes, you will get more power, but you will also get a ton of nasty distortion and possibly fry the amp. Besides, why do you want 2 left over channels for?
I would recommend to run the amp as it's designed. Clean power can be louder than more Dirty power. Any decent 5 channel amp should be plenty powerful to get you where you wanna go.
Unless you wanna go into the SPL shootout or something.
Old Feb 11, 2004 | 07:59 PM
crazymax's Avatar
Thanks that is what I thought..he just kept assuring me that it would be better and I didn't think it made sense, so I turned to the trusty forum... The system was all hooked up in my Integra and sounded awesome (although smaller vehicle)..Its a kenwood kac 859 and has worked awesome for me hooking it up to all 5 channels and with my ported JL audio 12W3D4 has plenty of bass..I just wanted a third party opinion before finishing the install..I was probable going to switch to 2 amps soon and a JL W7 anyhow. But this will do for now..
thanks for the advice..
Old Feb 12, 2004 | 06:00 AM
Tony Fernandes's Avatar
Tell this guy is doesn't know what he's talking about and don't take any more car audio advice from him!!
Tony
Old Feb 12, 2004 | 08:56 AM
C MAX's Avatar
[QUOTE=crazymax]Hello I have 5 channel amp..and I was told if I run the front mids, tweets, and rear speaker off 1 channel..same on the right side (using one channel for front and rear), and one separate for the sub that it would be better then running each speaker to each channel..no front and rear fade thou..and 2 channels won't be used..
he's half right.. you can run the hi-mid-and rear fill on one chanel if you run them in series only. this will keep them stable at 4ohm and the same for other channel..but from speakers you say you have , that's a very decent soundstaging setup. why would you want to waste a good set-up by trying to save amp space.. let those suckers breathe give them there own channels so you can have a little more dynamic control..
Old Feb 12, 2004 | 05:01 PM
crazymax's Avatar
Thanks..that is how I am going to do it..use all 5 channels..I am good at hooking equipment up..but not up on any shortcuts..which is a good thing obviously..
I'll just stick to the manuals and advice on the board..was just little concerned I wasn't getting all out of the amp..as he kept saying..
Thanks again..
Old Feb 12, 2004 | 10:43 PM
Thanks again..
If you're really concerned about getting all you can, then maybe you should use the two front channels to power the tweeters, the rear channels to power the midwoofers, and the 5th channel to power the sub. Use the amp's built-in xovers (if it has them) to HP the tweets, and LP the midwoofers and sub. You'll either have to 1) Get another amp to power the rear speakers. 2) Not use them. or 3) Use the HUs built-in amp for them, if it has one.
Just an idea. There's certainly nothing wrong with doing it the way you've finally decided on.
Tony
Old Feb 13, 2004 | 05:32 AM
nghtfthlngknvs's Avatar
so long as you're getting what you need, you don't need to tax your amp to its max.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
