Amp Ohm Help
Old Mar 1, 2004 | 07:06 PM
Hunter11's Avatar
Amp Ohm Help
These are the specs for my amp. I used to run 2 12's( 4 ohms each) off of it and bridge it and it would work for about a month or so and then it would go out. I had it fixed twice. I know for some reason it would go out because of the set up I was running. But, I was wondering if I could bridge it now that I am only running one 12(4 ohm) off of it. I just don't understand the ohm thing and why an amp goes out when it is bridged. Hopefuly these specs can help you out.
6 CH: 4 x 75 Watts RMS (4 ohms) [4 x 150 Watts peak] +2 x 150 Watts RMS Bridged (4 ohms) [2 x 300 Watts peak]
5 CH: 4 x 75 Watts RMS (4ohms) [4 x 150 Watts peak] + Bridged 150 Watts RMS (4 ohms) [300 Watts peak]
4 CH: 4 x 75 Watts RMS (4 ohms) [4 x 150 Watts peak] 4 x 100 Watts RMS (2 ohms) [4 x 200 Watts peak]
3 CH: 2 x 75 Watts RMS (4 ohms) [2 x 150 Watts peak] Bridged 150 Watts RMS (4 ohms) [300 Watts peak]
Old Mar 1, 2004 | 07:43 PM
jmax
You can bridge one pair of the channels to the 4 ohm sub. You will have 4 channels left over for mids and tweets.
Old Mar 1, 2004 | 07:59 PM
Hunter11's Avatar
So your saying that I can bridge my amp and it not eventually mess up?
Old Mar 1, 2004 | 08:04 PM
nismos14's Avatar
§è~® f®ÈÄk
yeah ur doing something wrong with the wiring, that why u kept blowing it out, or its a very bad quality amp what kind of amp is it?
Old Mar 1, 2004 | 08:20 PM
Hunter11's Avatar
I am bridgeing it right. It probably is the quality of the amp b/c it is a Jenson. It is the XA6040LX. Even thogh it is a Jenson it is pretty decent,at least I think so. I know there is better but my budget doen't think so, I am just working with what I have right know. I have had it for about 4 years too.
So is the combination of the ohms of the sub and the amp specs messing it up or is it just a shiity amp?
Also, do you think it will make a difference now that I am only running one sub?
Old Mar 1, 2004 | 08:50 PM
nismos14's Avatar
§è~® f®ÈÄk
if it was a pretty good amp, it wouldnt have needed fixing twice.....
consider getting a new amp check out the soundstreams here http://www.millionbuy.com/caudio-amp-sos.html
Old Mar 1, 2004 | 08:52 PM
Vortex SE's Avatar
Re:
Your original setup was wrong and therefore causing your amp to burn. When you were bridging to the two 12s (4 ohms each) your amp was seeing a 2 ohm load and probably was not stable at 2 ohms for long periods of time.
Now you would be bridging to one 12 and the amp would be seeing a 4 ohm load. Which it is stable at that load. Keep this setup with the hardware you have now.
Later...Vortex SE
Old Mar 2, 2004 | 05:35 AM
Hunter11's Avatar
Later...Vortex SE
Thanks for the info,I will see if it will work right now. If it doesn't, it is time for a new one.
And nismos14 you probably right if it was good it wouldn't need fixing.
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
