What Size Amp Do I Need?
Old Mar 9, 2004 | 07:55 PM
Hunter11's Avatar
I need a new amp but not sure on what amp to get. My sub is 200W RMS and 400W peak 4 ohm. Right now I am only running one 12 but may plan on running 2 in the future so I want to get an amp that will capable of pushing both if need be.
But my question is should I look for an amp that has a close RMS to my sub or close to the peak power.
Like, I am looking to get a Punch P3002
which has 75 W X 2 @ 4 Ohms RMS,150 W X 2 @ 2 Ohms RMS,300 W X 1 @ 4 Ohms Bridged RMS. Is this good for my sub esp being bridged.
I will be running the one sub bridged, so will I be putting 300W to that one sub? Is that sufficient enough?
Thanks for the help!!
Old Mar 9, 2004 | 08:51 PM
BLACKonBLACK98's Avatar
Former Vendor
find something that will do the 200 rms at 4 ohms but is also 2 ohm stable, and will do around 400 rms at 2 ohms.
Old Mar 9, 2004 | 11:17 PM
jmax
http://jbl.com/car/products/product_...er=GTI&cat=AMP
or
But in all seriousness get something that is adequate to push the sub in the enclosure you plan to use. Power handling is highly dependent on the enclosure. Going from 4 ohms to dual 4 ohms will be somewhat difficult unless you buy an oversized monoblock. Something rated at 300 - 500 RMS into 2 ohms. There is a wide range there because of the variability in enclosures and every amp is rated to differing standards.
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
