What spot to run power wire through firewall?
Old Mar 22, 2004 | 01:41 AM
Cool J's Avatar
i have a 97 and right now i am running my wire underneath the car up through the spare tire well. i want to run it through the firewall instead and go under the carpet so no one can clip my wires on the outside. anyways, is there a hole in the firewall where it can go through or will i need to drill one out?
Old Mar 24, 2004 | 01:12 PM
erty67's Avatar
Decal Specialist
looking into the engine compartment, look at the firewall next to the brake master cylinder. You should find a rubber grommet that you can poke through or remove.
Old Mar 25, 2004 | 12:33 AM
Cool J's Avatar
when you say looking into the engine compartment....do you mean by looking into the engine compartment when the hood is popped open or looking at it from under the steering wheel?
Old Mar 25, 2004 | 06:06 AM
erty67's Avatar
Decal Specialist
Open your hood and look at the motor...then look at the master cylinder and the look at the firewall to the left it the MC.
Old Mar 25, 2004 | 08:20 AM
Cool J's Avatar
i would do that except i dont know how the master cylinder looks like. alos, will the wire be coming in on the passenger or driver side?
Old Mar 25, 2004 | 11:47 AM
erty67's Avatar
Decal Specialist
OK, now you are making me nervous. the master cylinder is the thing that hold brake fluid...located on the drivers side opposite of the steering wheel.
Old Mar 25, 2004 | 01:46 PM
Cool J's Avatar
well i found a cutout on the inside but when i look in the engine compartment, it is metal and looks like it needs to be drilled through
Old Mar 26, 2004 | 10:08 AM
erty67's Avatar
Decal Specialist
keep looking....there should be a dime sized rubber grommet thqt you can remove. I'll try to get a pic of it for you when I get home.
Old Mar 26, 2004 | 03:51 PM
speakeraddict's Avatar
I need to find a place on the firewall to run a 4ga. through on my 2nd gen.
For the life of me I can't find a decent place.
I don't have a problem with drilling. It just seems there is stuff in the way wherever I can fit a drill.
speakeraddict
Old Mar 26, 2004 | 06:52 PM
5 spd's Avatar
what is the largest guage wire I can fit through this hole?
(I need to take a look myself...)
Old Mar 26, 2004 | 09:30 PM
erty67's Avatar
Decal Specialist
i've got 4ga going through it
Old Mar 27, 2004 | 10:23 AM
driver824's Avatar
i just drilled from the inteior out where the clutch would be mounted...
blake
Old Mar 27, 2004 | 01:56 PM
erty67's Avatar
Decal Specialist
follow the red wire to the hole
Old Mar 27, 2004 | 03:48 PM
thekenone's Avatar
u could always go thri the door jam. i always do it that way and run it under the ruber trim. i don't know about 4 ga though. but from battery side of engine go towards the driver side door and then u can go into the car. and if u r worndering i have never had my wire ppinched. 1 think i have 6 gauge. i would test it with 4 before wiring it all up to make sure.
Finkle
Sep 27, 2015 09:53 PM
sake1bs
Sep 19, 2015 09:32 PM
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
