Might be changing setup...need new amp.
Old May 21, 2004 | 09:22 AM
Maxima Dan's Avatar
Can anyone think of a amp that is small enough to fit under the front seat of a 5th. Gen max, put out around 1500W into either .5 or 2 Ohms, and run cool enough that it won't fry? All I can think of is MMATS D14002 or D1400.5.
Old May 21, 2004 | 09:50 AM
slickrick's Avatar
http://www.cbrstereo.com/index.asp?P...ROD&ProdID=485
edit: what about this?
http://www.cbrstereo.com/index.asp?P...ROD&ProdID=964
Old May 21, 2004 | 11:36 AM
Maxima Dan's Avatar
That RF amp looks interesting, how hot does it run.
Old May 21, 2004 | 11:38 AM
slickrick's Avatar
i have never used an rf amp but if its under the seat shouldnt there be adequate cooling anyway? especially if you turn on the floor vents.
Old May 21, 2004 | 12:24 PM
Maxima Dan's Avatar
Depends on if your running the heater or not.
Old May 21, 2004 | 02:45 PM
slickrick's Avatar
this is true. i just never use that here in fl. well obviously running at 2 ohms will help the amp run cooler. did your old amp have overheating problems?
Old May 21, 2004 | 02:59 PM
MannyNJ2k2max's Avatar
MaximaDan......Isn't there a Zapco you could fit in there? C2k6.0X?
Also the new Treo Engineering amps have a nice squarish size to them....very little info out on them tho but are suppossedly very nice- check Termpro forum
Old May 21, 2004 | 03:11 PM
Maxima Dan's Avatar
Nope. I'm running a MMATS D200HC and that thing never even got warm. Even after it set my Brahma on fire!
Old May 21, 2004 | 03:14 PM
Conrad283's Avatar
I need a truck
Why would you put it under the seat. That's just money that's spent on wiring.
I have a Rockford 700S if that's what you're lookin for. It should fit underneath your seat
Old May 21, 2004 | 04:23 PM
Maxima Dan's Avatar
More room in the trunk. What else goes under the front seat?
Old May 21, 2004 | 05:49 PM
slickrick's Avatar
you could mount it behind the rear seats and shouldnt really take up any space.
Old May 21, 2004 | 07:34 PM
Maxima Dan's Avatar
Already got one there.
Old May 21, 2004 | 07:37 PM
Maxima Dan's Avatar
Those Treo amps look sick! I have no idea how to get any more info on them plus they are a bit more than I was looking to spend. Kinda the same story for the Zapco. Although, I would be really tempted if I could find a place to put the Zap C2K9.0. That amp would be perfect, just too big and too expensive. Good suggestions though
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
