Kenwood KDC-X979 Sub Out Help
Old May 24, 2004 | 09:55 PM
iansw's Avatar
I got this deck today and promptly headed to teh garage to install it.
Hooked up all wiring and found that the deck has the following pre-outs (RCA's).
L/R Front
L/R Rear
1 Sub Out
1 Center
I have an amp wired in mono to 1 12" Sub. The Amp requires 2 Inputs (L/R to give the sub full power in bridged mode. (PPI PC2300 Amp).
But there's only ONE Sub Out jack! The Center channel I thought maybe can be used as a Sub Out, but it appears that I can't even turn it on after looking in the manual.
So what do I do to make this work? Is using a splitter on the Sub Out acceptable? Why would they design Kenwood's top of the line deck this way?
The Deck has Dolby Surround - does that have something to do with it?
IanS
Old May 25, 2004 | 05:52 AM
MacAlert's Avatar
Why do you want to split the sub-out? Subs are only one channel speakers, I think.
Old May 25, 2004 | 06:17 AM
iansw's Avatar
Because the amp does not have a function to allow 1 channel to put full signal for bridged mode. I am running the sub as bridged. (Bridged = L/R Channel combined as 1 output)
Basically, with only 1 input on the amp, the sub is 1/2 as loud as it should be.
Old May 26, 2004 | 10:21 AM
NEW2DAGAME's Avatar
Seems like using a Y cable would work, one female-two male.
Old May 26, 2004 | 04:46 PM
nismos14's Avatar
§è~® f®ÈÄk
so the sub channel only has one rca output? yes a splitter would be fine.
Old May 27, 2004 | 02:47 AM
maxceleration's Avatar
yeah, you're gonna have to get a splitter...
or a new amp.
Old May 27, 2004 | 06:48 AM
iansw's Avatar
I'
ve never seen a car amp that only has 1 input.
Anyway - I bought a splitter 2 day ago - works fine.
Ians
Quez
Jun 14, 2001 09:39 AM
C-Dawg
Feb 22, 2001 02:41 PM
C-Dawg
Feb 21, 2001 10:45 AM
HoboPro
Dec 21, 2000 11:29 AM
HoboPro
Dec 18, 2000 09:39 PM
