can i run a remote wire off my cig lighter fuse?
Old Aug 22, 2004 | 02:42 AM
2 Da Max's Avatar
i have a stock bose head unit and i am curious if i can run a remote wire from my cig lighter fuse since it has a constant 12v source, is this ok or is this too much volts for the amp? thanx
Old Aug 22, 2004 | 05:41 PM
cobymoby's Avatar
Yes you can. are you just using it to turn an amp on?
Old Aug 22, 2004 | 09:11 PM
2 Da Max's Avatar
yes but my amp blew yesterday. think thats the problem?
Old Aug 23, 2004 | 08:10 PM
image's Avatar
it will always stay on.. as long as you know that.... lol
Old Aug 24, 2004 | 09:34 AM
2 Da Max's Avatar
is there anything else besides that and the ignition, because i dont want to blow another amp again
Old Aug 24, 2004 | 10:47 AM
image's Avatar
Umm the ideal way is to find the power wire on your head units harness and they make these blue things that just tap into it.. takes 5 seconds. I'd really reccomend doing that... If your going to do it, do it right. Just my .02 cents.
Old Aug 24, 2004 | 08:21 PM
2 Da Max's Avatar
i put it on something called AUDIO fuse is that ok too?
Old Aug 24, 2004 | 09:09 PM
nostrixoxide's Avatar
Yes, just make sure your amp will turn off when the car is turned off.
Old Aug 26, 2004 | 12:18 AM
munchichee59's Avatar
omg please use a test light if not a multimeter to find a switched power source before you fry something else. Those "blue" things are called T-Taps and come in red,yellow,and blue and you'll need a male connector to plugin to it. I wouldn't use the cig lighter considering installing a switch to turn on/off the amp is more trouble than finding an accessory wire under the dash or removing 4 screws to pull out the radio.
Old Aug 26, 2004 | 08:53 AM
2 Da Max's Avatar
na its all good now i got it on my audio fuse under the dash
Old Aug 26, 2004 | 09:32 AM
image's Avatar
Yea T-Taps.. they own man. <3 all those years that's what i was missing. I think munchi will agree with me, if you going to do something bro, do it 100% right or not at all... Im just throwing in my .02 cents, however im here to help you find a hot wire so you can tap into.. Meaning its still your choice we'll try to assist you anyway we can...
Old Aug 26, 2004 | 04:35 PM
2 Da Max's Avatar
thanks guys, so what your saying is dont leave the remote wire on the audio fuse under the dash? because if i cant ill go and take apart my head unit and tap it in from there.
Old Aug 26, 2004 | 04:52 PM
image's Avatar
Iono about the fuse.. but just do it right and take your HU apart and tap ino the power wire. Will only take a few minz
Old Aug 26, 2004 | 05:44 PM
2 Da Max,
If you have a aftermarket H/U then wire the remote to the remote out (blue wire) on the H/U. If you are using the factory H/U the audio fuse is just fine. I had mine set up the same exact way with no problems. the audio fuse is factory H/U's power wire. So it's ok to hook it into audio fuse.
Old Aug 26, 2004 | 08:30 PM
2 Da Max's Avatar
thanks alot nostrixoide i really appreciate your help, youve helped me out more than anyone else i have asked at the electronics store
Old Aug 27, 2004 | 04:09 PM
no problem man, that's what this place is here for, (Helping out)....
I just hope everything sounds good?
Old Aug 27, 2004 | 08:10 PM
2 Da Max's Avatar
yes im lovin the sound man
The Frye
Sep 2, 2021 11:03 AM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Viralkill
Aug 16, 2015 05:09 PM
