Where to run 4g power wire in '00
Ok I can't find any holes in the firewall...are there any or am I just blind? If I have to drill, anyone know of a safe place on the drivers side where I won't be drilling through any electronics? Thanks.
You can run your 4 gauge wire through the emergency brake gromlet. You'll have to take the right side of your driverside front wheel well off so u can get to the backside of the gromlet. It's easiest to run the wire down the slit in the engine right above the wheel well and then thru the emergency brake gromlet. Hope this helps.
sake1bs
Sep 19, 2015 09:32 PM
conansriver
Sep 3, 2015 06:38 AM
doobadoo
Aug 15, 2015 06:43 PM
