2000 SE Tweeters...
Old Oct 28, 2004 | 08:23 PM
jmal's Avatar
2000 SE Tweeters...
I haven't even pulled the A-pillar and looked at them yet, but are they easily replaceable with some component tweeters?
Old Oct 29, 2004 | 03:27 AM
Lystat2k2se
Dunno, havnt done mine yet but they shouldnt be to much of a pain most component tweets are pretty small and if nuthing else u can make them fit with a lil home made bracket or whatever
Old Oct 29, 2004 | 05:38 PM
MIXXMAX's Avatar
Only if you plan on installing them inside the pillar like the stock ones. The stock ones are super thin. It's hard to find some aftermarket tweets that slim in size to fit behind the pillar. Like someone said, if you can modify the bracket somewhat, you can make it fit. Actually, there isn't alot of room behind those pillars.
Old Oct 30, 2004 | 07:08 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes its very sinple. Ive done dozens of components including Eclipse,DA,Arc,Rainbow,PG,etc....Just mount the tweet on the pillar itself and disregard the factory bracket.
--Don
Old Oct 30, 2004 | 07:23 AM
friendhasmax's Avatar
--Don
yea do what Don does and just tape the tweeter to the A-pillar using duct tape
Old Oct 30, 2004 | 09:09 AM
Pearl96Max's Avatar
Hot glue, not duct tape
Old Oct 30, 2004 | 12:48 PM
i thought u taped it to the actual panel once?
Old Oct 31, 2004 | 03:43 AM
Pearl96Max's Avatar
Nah they were all hot glued, but then I used duct tape to seal it off.
Old Oct 31, 2004 | 03:54 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I used the supplied screw from JL Audio and drilled a small pilot hole in the A Pillar.
Old Oct 31, 2004 | 08:29 AM
ah ok, now i remember
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
