Kenwood cd changer HELP
Old Nov 2, 2004 | 06:36 PM
huyqvu's Avatar
the car came with a kenwood kdc319 and kenwood cd changer. not sure of the model numbers. anyways took i it out to plug in some rca and remote for a new amp. after putting it back together the the hu wont recognize the cd changer. checked connections and are all fine. first time dealing with a cd changer and not sure if i missed something. any ideas?
Old Nov 2, 2004 | 07:57 PM
SuperChris's Avatar
Infiniti 35 Double G's
two possibilities: the CD changer might have a little switch in the back or just inside the sliding door that's set on either "O" or "N"; try switching it to the opposite setting. also, if the HU has a little "reset" button (really small, you'd need a uniball pen or small nail to push it) on it, try that too.
my best guesses...i got a Kenwood also; good luck.
oh yeah, make sure the changer isn't installed at a weird angle; Kenwoods can only be mounted flat or 90 degrees, nothing in between.
Old Nov 3, 2004 | 05:49 PM
huyqvu's Avatar
thanx for the input. went out and checked everything again. after about 30mns freezing my *** off checked the din connector to the hu, one of the pins were bent. straighten it out and bam the sucker works. now all i gotta do is find out how to isolate the changer so the sub doesnt vibrate it so much.
Old Nov 3, 2004 | 07:12 PM
SuperChris's Avatar
one of those 13-pin connector wires?
Old Nov 4, 2004 | 01:45 PM
huyqvu's Avatar
yup, took a small flat screwdriver to straighten it out and bam it worked. but i might just ditch the shiet since i can even use it at moderate volume levels. everytime the bass hits it stalls. to hell with the kenwood, gonna go look for a pioneer hu.
Old Nov 4, 2004 | 03:26 PM
Igor911's Avatar
Sorry Chrissy your wrong
I have a Kenwood custom mounted in my glovebox. It prolly sits at a 50 deg angle and works great.
Old Nov 4, 2004 | 06:56 PM
SuperChris's Avatar
just relayin' what the directions say...and manufacturers NEVER lie!
Old Nov 4, 2004 | 07:04 PM
Igor911's Avatar
kraweb
Feb 2, 2001 08:48 AM
HoboPro
Dec 21, 2000 11:29 AM
HoboPro
Dec 18, 2000 09:39 PM
CandiMan
Dec 15, 2000 07:22 PM
karl
Nov 18, 2000 09:59 AM
