i just got a fog light, whats the purpose of all these relays and wires?
i bought this fog light kit, and it has so much wires and all these little bull shiit things. can i just run the pos. and ground, and make a direct switch with an inline fuse? i mean i have over 6 diff. wires and a relay and all this crap. i mean doesnt the fog run off of 12volts anyways? or would i blow something if i ran it directly off the battery with a switch?
damn if you thikn about doing this then u should have someone do it for you. them black shiits are the relays to raise up the amperage=current. you need this so that u don't draw alot of current from the car. think of it as a cap for your system. do u know how much power is drawn from ur fogs?
you dont have to use the relay if you direct wire the positive and negative to the battery with a fuse and a switch. the relay is provided if you want to use aomething else to turn ur fogs on other than a switch, such as using the radio output to turn them on. get what im saying?
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
