Alarm and Remote Start Wiring Information
Old Jan 23, 2006 | 03:35 PM
  #41
kpr10is's Avatar
5th gen NSS wire: Pin 44 at the ECU, IIRC-green/orange.
It can also be found under the intake...but you have to remove the intake (if stock) to get to the wiring, so I find this is easier.
Someone else can chime in for the 4th gen cuz I dont have any pics or cool **** like that. Pics here are courtesy of studman.
-Kevin
Old Jan 23, 2006 | 04:35 PM
  #42
Igor911's Avatar
FYI - It's green/white in my car...
Old Jan 23, 2006 | 04:43 PM
  #43
kpr10is's Avatar
Cool, I was probably wrong two posts above...I knew it was green/something.
Old Jan 26, 2006 | 08:29 AM
  #44
Deckdout2's Avatar
Play with my balls
Thanks guys!
Old Mar 8, 2006 | 10:23 AM
  #45
mszilves's Avatar
Thanks for the info guys!
Old Mar 19, 2006 | 04:26 PM
  #46
SurraTT's Avatar
HR Swap Pioneer
some one know anything about door unlock and lock features, its really got me
i have it where ti unlocks sometimes but then it wont
the alarm has unlock (nc com no) lock (nc com no)
anyone??
Old Mar 23, 2006 | 02:50 PM
  #47
SurraTT's Avatar
HR Swap Pioneer
ya ok i figured it out
thanks for all the replies
WTF
Old Mar 28, 2006 | 09:01 PM
  #48
t0mmyr's Avatar
how about posting the door and trunk triggers? did i miss it?
i bought diodes but i forgot how to wire them, its been a year since i did alarms
i have a 5th gen 2001 maxima
Old Mar 28, 2006 | 09:47 PM
  #49
kpr10is's Avatar
You missed the trunk pin, it was on page 1, as purple/yellow in pin 38 at SECU, which is located to the passenger side of the steering column.
But your right, I didn't see door trigger wiring, so here it is, for 00-01 at least:
Find lt. blue for the drivers door in pin 29, red/blue for the passenger front door in pin 40, and red/white for the rear doors in pin 28. Use all 3 wires and diode isolate each.
These diodes need to go with the stripe facing away from the brain.
Old May 2, 2006 | 01:14 PM
  #50
Pearl96Max's Avatar
I tend to get a bit irritable
INFO ONLY, NO DISCUSSIONS.
Make your own thread.
Old Aug 8, 2006 | 10:24 AM
  #51
Primetime0625's Avatar
Does anybody know where the turn signal wires are located on a 2000 Maxima. I am looking to hook up my led mirrors and I need to find out where they are located.
Old Aug 9, 2006 | 05:13 PM
  #52
can somebody please answer my question?
Old Aug 15, 2006 | 06:10 PM
  #53
cobourg's Avatar
hi guys can someone post 1991 wireing with tach to coil + an - thanks
Old Nov 20, 2006 | 07:19 AM
  #54
HeavyC's Avatar
Originally Posted by kpr10is
2005:
12volts: green (40A), +, ignition harness
Starter: black/red, +, ignition harness
Second Starter: black/yellow, +, ignition harness
Ignition: black/red, +, ignition harness
Accessory: red, +, ignition harness
Second Accessory: white/blue, +, ignition harness
Keysense: black/red, +, ignition harness or BCM pin 37. The BCM (Body Control Module) is between the steering column and the fuse box.
Power Lock: blue or pink/blue, -, driver module in door. Meter this wire while turning the key in the driver door key cylinder.
Power Unlock: red (double pulse), -, driver module in door. Meter this wire while turning the key in the driver door key cylinder.
Parking Lights(+): red/blue, +, driver kick harness to rear
Door Trigger:The LF door is lt. blue in pin 62, the RF door is brown/white in pin 12, the LR door is red/black in pin 63, and the RR door is blue/red in pin 13. Use all four wires and diode isolate each.
Dome Supervision: red, -, BCM pin 48
Trunk Pin: purple/white, -, BCM pin 57
Hood Pin: NA
Trunk Release:blue or blue/white, -, BCM pin 30.
Factory Alarm Arm:arms with lock
Factory Alarm Disarm:disarms with unlock
Tachometer:NOT red or black, ac, any coil or injector
Brake Wire:red/green, +, brake pedal switch
Horn Trigger:green/white, -, horn switch
I'm having a hard time understanding this. Where exactly are the 12V constant and 12V switched wires. I know how to perform the tap in, I'll just be damned if I can't figure out where they are on this car.
I'm not super familiar with the term "ignition harness" I'm a newbie at a lot of this stuff. If someone could just tell me where that is exactly so I can find it and look at it myself I'd appreciate it a ton.
Old Dec 22, 2006 | 07:22 PM
  #55
PeterUbers's Avatar
Car: 1997 Maxima
Wire: trunk pin at BCM -- how do you get to the BCM (where is "below radio") and which color/# wire is it?
Old Apr 11, 2007 | 03:16 AM
  #56
Hammy
1995 Maxima- Which wire will is switched to 12v whem key is in the ignition, and shuts off when removed.
Old Jul 10, 2007 | 11:40 AM
  #57
muggzy's Avatar
Hi. new here.. Not sure if this alarm related.. But i'm helping some on install an Pioneer HU with GPS on is 05' SL, Maxima.. The instructions call for tapping into the speed sensor wire... does anyone here know which it is on the ECU? Thanks in advance!
-M
Old Aug 19, 2007 | 02:13 PM
  #58
143218's Avatar
factory alarm
hello everybody
i bought my maxima used love it. it did not come with the remotes for the doors. the problem that i am having is that my alarm now comes on and the only way to disable it is to disconnect one of the cables that goes to the positive battery terminal. the question that i have is this is there any way to disconnect the factory alarm and not use it any more. i have a 1994 maxima gxe shoc. i love the car but this is its only downfall.
any help you guys could give would be awsome
thanks
Old Oct 4, 2007 | 08:45 PM
  #59
Caliplaya023's Avatar
Fresh Outta B-Town, NY
HELP!
SOMEONE HELP!!! my security system is being stupid, when i open the door it beeps at me, not letting me lock the doors with the remote, i have to open one of the rear doors and lock it with the driver door shut, once in a while it wont beep and i can lock it with the remote, and unlock it when i get in the car again, but thats it! whats the problem???? i just got my first max and im new here SOMEONE PLEASE HELP!
Old Feb 27, 2008 | 12:15 PM
  #60
DcMaN's Avatar
FYI: The NSS wire in the 5th gen is GREEN/ORANGE on automatic, and GREEN/WHITE on manuals.
Old Mar 25, 2008 | 12:21 PM
  #61
Deckdout2's Avatar
Play with my balls
It would be great for someone to post in this thread with the exact location and color of the Reverse Signal Wire for a 5.5 gen Maxima.
Old May 25, 2008 | 10:17 AM
  #62
goode79's Avatar
1996 NISSAN MAXIMA 4TH generation
I have a1996 Nissan Maxima and I'm trying to install a aftermarket remote starter and Keyless entry and the instruction that came with it just show colors does anyone have step by step instruction or knows hoe to install and can give me that knowledge
Old May 25, 2008 | 11:35 AM
  #63
mendon99's Avatar
tastey wheat
green/white (+) @ drivers kick, harness to rear.
Old May 26, 2008 | 06:23 AM
  #64
goode79's Avatar
I have a ultrastart XR-Pro remote starter and keyless entry and the only instructions that came with it are color matching does anyone have any step bp step directions to install after market remote start and keyless entry systems on a 1996 Nissan Maxima
Old Nov 18, 2008 | 12:57 PM
  #65
Digital Alchemy's Avatar
Create From Nothing
2004 nissan maxima 6spd (this may also apply through 2006)
NSS Wire - Neutral Safety Switch - Green with white strip - ECM pin 102
Old Dec 10, 2009 | 08:49 AM
  #66
dragracer440wedge's Avatar
Hello, I have a 3rd gen Maxima 1990.I want to install a alarm system with remote start.It has the factory security system and want the aftermarket system to work with it if possible. Awhile back I was on this site a found a link for the wiring of alarm systems,I can't seem to find it. Help Please.
Thank you
Ezra
Old Dec 16, 2009 | 01:35 PM
  #67
Professor's Avatar
2000 Max info ?
Old Feb 1, 2011 | 10:37 PM
  #68
Tommiekatt916's Avatar
http://www.the12volt.com/installbay/...rd/Nissan.html
Free wire diagrams open to the public... I use it all the time.
Old May 19, 2011 | 12:49 PM
  #69
MiamiMaxima's Avatar
2005:
Hood Pin: NA
Is this like for sure for sure????
Old May 19, 2011 | 02:28 PM
  #70
mendon99's Avatar
tastey wheat
yes. question?
Old Nov 10, 2011 | 05:39 PM
  #71
skylinemax82's Avatar
how do i permently dissable my factory alarm on my 97 max so that i may install an aftermarket alarm system. i boaught the car used and it does not have the remotes and if i dont open my trunk before putting my key in the drivers door, my alarm goes off. i just want to put a new alarm in but i need to know how to permenently dissable my factory one so i can do this
Old Nov 10, 2011 | 08:34 PM
  #72
Pearl96Max's Avatar
You don't need to. OE alarm is triggered by lock and unlock. Putting in an alarm will do lock/unlock therefore also disabling the OE 'alarm'.
Old Nov 10, 2011 | 09:40 PM
  #73
yeah but my factory alarm is falty and does arm/dissarm by locking and unlocking the doors, i cant even put my key in the door without the alarm going off unless i pop the trunk first
Old Nov 10, 2011 | 09:41 PM
  #74
*does not arm/dissarm by lock/unlock
Old Nov 10, 2011 | 09:51 PM
  #75
Pearl96Max's Avatar
Have you tried sitting in it, then press lock/unlock ?
Old Nov 10, 2011 | 10:07 PM
  #76
yes that doest do anything either, i baught the car used it didnt come with remotes and no unlocking or locking of the inside or outside arms or dissarms it and get this, i can put down my window, lock my doors, and put my hand through the window and open the door from the inside and nothing happens. i can lock my doors and try to open the door from the outside with the door handle and nothing happens, i can lock my doors and jump up and down on my car and nothing happens. i put my key in my drivers door and the alarm goes off unless i pop the truck first, the system is faulty as hell and i need to know how to get it out or permenantly dissconnect it by cutting wires so that on my new one i dont have and problems
Old Nov 11, 2011 | 06:11 AM
  #77
what color wire on the ignition swtich is the one where when you turn the kley onto the "on" position??? on a 97 nissan maxima
Old Nov 14, 2011 | 12:13 PM
  #78
Goomz's Avatar
here's some useful info for (at least) a 98, possibly all 4th gens. if anybody would like their rear defroster to activate with the push of a (few) button(s) when the car is remote started, the wire in the car is grn/red, negative polarity, located at the defroster switch.
then, grab a relay and wire it at follows: 85: fused 12v constant. 86: r. defroster/aux output from remote start brain. 87: grn/red from defroster switch in car. 30: chassis ground.
to activate it, just follow the directions from your remote start unit to activate whatever aux channel you used to trigger the switch.
Old Sep 18, 2014 | 02:10 PM
  #79
Nissan maximum's Avatar
help
I installed a remote starter on my 96 maxima but my car will only start if the key is in the ignition at the"on" position.my key doesn't have a chip.do I need a transponder bypass?
Old Jul 31, 2017 | 03:02 PM
  #80
uptowndrizzy's Avatar
can someone help me I just put a push button start n my 2000 max but cant figure out what the thick red wire is I have 3 thick wire grn,red, and red/blk please help cant find out nowhere thanks n advance
mvm062
Nov 30, 2020 09:00 AM
intimidator
Sep 5, 2015 07:23 PM
conansriver
Sep 3, 2015 06:38 AM
umnitza
Sep 1, 2015 01:03 PM
maximaham
Aug 7, 2015 01:11 PM
