those with a system in their trunk
Old Dec 30, 2004 | 01:44 PM
  #41
tpduke112's Avatar
ok Ill go let it run for a while. what about the amp size for the 10s, what do you think?
Old Dec 30, 2004 | 02:32 PM
  #42
tpduke112's Avatar
Just let it run for about 30 mins with the cd player off. Turned it on, nothing, still no security light....
Old Dec 30, 2004 | 03:07 PM
  #43
Maxima Dan's Avatar
The battery doesn't really charge at idle. That's how the charging system guards against overcharging the battery. Your best bet is to find a charger and hook it up overnight. If it is not accepting or holding a charge then the batt is dead.
Old Dec 30, 2004 | 03:14 PM
  #44
tpduke112's Avatar
Would just driving it around for about 30 mins do it?
Old Dec 30, 2004 | 03:20 PM
  #45
BlkShadow01
like maxima dan said..if it doesnt do anything...then its prolly dead
Old Dec 30, 2004 | 03:21 PM
  #46
BlkShadow01
but then again if your car starts everytime..then i dont know wats up
Old Dec 30, 2004 | 05:26 PM
  #47
Maxima Dan's Avatar
Most likely no. What exactly is the problem again? Is the car not starting, or is it failing to start right after you shut it off. You also have to remember that a battery has some self healing qualities. If it is healthy, it will naturally come back to life if you just let it sit for a while, say overnight, assuming it's not too cold out. Now if you can start it in the morning but are unable to restart it then it sounds more like an alternator. You can check the alt by hooking a DMM up to the + batt terminal set to DC Volts. It should come up to 14+V at around 2-3K RPM...not at idle. If the voltage never rises above 13V then the alternator is toast.
Old Dec 30, 2004 | 05:47 PM
  #48
tpduke112's Avatar
The start of the car seems to be fine. The Security light on the amp isnt on, nor are the subs. They just went off for no reason and I cant figure out why.
Old Dec 30, 2004 | 06:19 PM
  #49
Maxima Dan's Avatar
Well then it's probably not the car batt or the alternator. Are there any lights on the amp lit and have you measured the input voltage yet?
Old Dec 30, 2004 | 07:25 PM
  #50
tpduke112's Avatar
None of the lights are lit and I havent measured the input voltage yet.
Old Jan 1, 2005 | 12:02 AM
  #51
CO2kmax
To stop license plate rattlefirst get rubber washers for all 4 the screws and get some foam and glue it to the pack of the lisence plate, or something that will obsorbed the movement of the lisence plate. Just got 2 play with it till you get it rite, and if all else fails turn it up as loud as it can go so you cant hear the rattle.
Old Jan 1, 2005 | 04:59 PM
  #52
craig10114's Avatar
i used expanding foam in my trunk lid...lost the key hole back there but i have the least rattle out of anyone i know
Old Jan 2, 2005 | 06:23 PM
  #53
A32Matt's Avatar
i get a terrible rattle from my rear deck, trunk lid, and somewhere inside my left rear fender. I gotta figure out how to fix the trunk lid and the fender, the rear deck should be easy though.
Old Jan 2, 2005 | 06:31 PM
  #54
2 Da Max's Avatar
i dont know about you guys, but what about those metal rods that are connected to the trunk? i think thats where my rattles come from. my friend also told me to adjust the tensioner on my trunk latch to make it tighter. is that true?
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
