Input on stock 97 SE BOSE headunit? CD Changer?
Old Mar 7, 2005 | 04:12 PM
MPScan's Avatar
I have a Sirius Sat Radio and use the FM Modulator. I have read on the Sirius forums that if you have a headunit with a CD Changer connector, you can get a cable to make that like an input and hook it up to the satellite radio.
I went through 4-5 websites and nobody makes a cable for the 97-99 BOSE headunit!!! There are cables for 100's of other cars.. just not the Maxima.
Where can I find one?
Old Mar 8, 2005 | 10:07 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Expensive but this should do the trick. http://www.logjamelectronics.com/soundauxniss.html
It's too much for me, so i just stuck with the FM modulator.
Old Mar 9, 2005 | 09:44 PM
VQuick's Avatar
Chassis Freak
Sirius via FM modulation = waste of Sirius. I'd do anything I could to get a real input that's doesn't ruin your sound quality. Sorry I can't help.
Old Apr 3, 2005 | 01:36 PM
MPScan's Avatar
I have just been looking around and came across that converter also. But it says 1998+ BOSE Maxima headunits. I have a '97. Will this still work with the 97 BOSE?... (yea, I have the changer output and the CD CHG button)
Old Apr 3, 2005 | 02:33 PM
cgm95gle's Avatar
Yes, it should work. The 97-98 Maximas came with the same HU. If the HU number (located on the cass. tape "door" above the BOSE logo) says CN555, it will definately work as I have that same HU in my car with a Soundgate adapter. The only problem you will have is with alternator whine. I haven't found a solution to this yet with my Audiovox Sirius tuner, but when it gets warmer here in Jersey I plan on ripping everything apart and fixing it.
James92SE
142
Jan 2, 2024 09:23 AM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Fbana41
Aug 29, 2016 12:18 PM
A32goldylocks
Sep 2, 2015 06:39 AM
