resin molds
resin molds
i see some of you have clear glass like materials on top of your amps. is that made from a resin substance. i was think of making a mold with my trunk dimensions and laying this clear glassy pieice on top of my amps which will be embedded underneth.
Originally Posted by ramtaajogi
can u mold it yourself. i no you can make your own molds with resin simple pour and let dry.
Well, depending on meticulous you are with the project will determine how it turns out. Strength? Most fiberglass molds will support at least your bodyweight after 3 to 4 layers...they stuff is INCREDIBLY strong.
What are you working on?
That shouldn't be too hard. Just remove everything in the trunk, tape it off, put down 2 -3 layers and oyu have your base. The remaining layout is up to your imagination and ability to use mdf. Depending on how you od it, you will probably want to stretch some polar fleece over what you want, add the resin to the fleece, and shape/sand to your liking.
ptatohed
Jul 24, 2001 12:17 AM
emax02
Jan 10, 2001 06:46 AM
