amp settings
Old Mar 10, 2005 | 04:51 PM
ramtaajogi's Avatar
amp settings
i installed my amp and sub today and now its time to set the passes and gains. gains i can do using the 3/4 method, but how do i know what i set my high pass and low pass filters too. is there a nice website i can view to set this up. also...what do i exactly do to break in a sub. just relax on the sub for a while.
Old Mar 10, 2005 | 05:04 PM
A32Matt's Avatar
if you can, turn the high pass filter off. you shouldn't have any treble coming through your sub. i have my LPF set through my headunit at 80Hz, so that way anything above 80Hz will not enter my sub. if it's a dial, i'm not too sure how to set it. what kind of amp do you have?
Old Mar 10, 2005 | 05:41 PM
AscendantMax's Avatar
it should be the same format. turn the low pass filter **** to whatever freq you want. anything above the set mark won't reach your subs. i have mine set at 80 hz.
what make and model amp?
Old Mar 10, 2005 | 06:20 PM
ramtaajogi's Avatar
a32matt...i have a 4 channel brided..so i have a high pass for my front speakers..and a low pass on my subs. just wanted to know how to "tune" it all. got a hifonics 4400 bythe way .
Old Mar 11, 2005 | 09:33 AM
Micah95GLE's Avatar
You should run your crossover points as low as your front speakers can handle. I have my fronts highpassed at 65 Hz and my subs lowpassed at 70 Hz. This creates up-front bass, so your ears don't hear the mids and highs at the front of the car and the lows at the rear of the car- it all blends together at the front if you keep the midbass frequencies out of the subs.
I tune the system by shutting off the sub and running only the front speakers. I set the lowpass at around 50 or 60 Hz and then turn the volume up, using a bass-heavy CD. Once I determine the lowest frequency that the front mids can handle, I set the sub lowpass point at the same point, and maybe alter +/- 5 or 10 Hz to fine tune.
Old Mar 11, 2005 | 03:57 PM
ramtaajogi's Avatar
thanks..thats exactly the help i needed.
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
