2001 maxima GLE hole on firewall
Old Jul 5, 2005 | 07:17 PM
dafowl1's Avatar
Is there a hole in the firewall where I can feed the hot wire through or do I have to drill one. If I have to drill one whats the best location. Thanks
Old Jul 6, 2005 | 07:57 AM
filtor1's Avatar
Depends on what size wire your using. 4ga, you can cut the stock gromet and jam it through. 0ga, drill a new hole.
Old Jul 7, 2005 | 09:17 AM
unrealii's Avatar
I ended up drilling for my 4ga wire. There is a diamond shapped cover, which I had removed then drilled through.
Old Jul 9, 2005 | 08:04 PM
rjgilardi's Avatar
i also drilled through the firewall under the diamond shaped cover, make sure you use a grommet so you don't chew up your wire on bare metal. That would cause a short and your fuse to blow. Or your car to catch on fire, (worst case scenario).
Old Jul 9, 2005 | 10:12 PM
GrazsRootz's Avatar
wise words
CRizz
41
Jun 7, 2021 05:42 AM
Finkle
Sep 27, 2015 09:53 PM
rtirbany
Sep 8, 2015 11:46 AM
District
Aug 15, 2015 08:23 PM
wpr
Aug 5, 2015 03:28 AM
