Subwoofer buzz
Old Aug 24, 2005 | 02:52 PM
NAGADOIT's Avatar
Subwoofer buzz
05 Max w/ base BOSE
I have the PAC converter to run an amp & sub
It just started doing this: when I remove the key from the ignition, the sub buzzes for about 5 seconds. It seems that it’s still drawing a signal/power.
What gives?
Old Aug 24, 2005 | 03:12 PM
sunten1
Is this an aftermarket sub?
If so check the Lead wire to make sure that the sub turns off when the car turns off.
Old Aug 24, 2005 | 03:17 PM
NAGADOIT's Avatar
yes...aftermarket
yes...the amp turns off...5 seconds later
Old Aug 24, 2005 | 06:37 PM
2 Da Max's Avatar
that happens because you connected you remote wire to another fuse or accessory. so when the keep comes out, the amp is off but its still getting a signal becuase there is always constant power from the battery, and the remote wire is powering it as well.
im assuming you have the remote wire connected to an accessory fuse, you should connect it to the AUDIO fuse so when the radio comes off the amp comes off aswell
Old Aug 25, 2005 | 04:54 PM
Ohiomike1101's Avatar
2x check the ground.
Old Aug 25, 2005 | 06:44 PM
nismos14's Avatar
§è~® f®ÈÄk
And how would the ground affect this?
What kind of amplifier are you using?
jskirwin
Jun 8, 2016 08:49 AM
sliptap
Sep 30, 2015 05:57 AM
starman9215
Aug 11, 2015 06:51 PM
