Couple of questions
Old Oct 24, 2005 | 01:04 PM
NismoGTR's Avatar
Couple of questions
Ok i have a 02 Max with the Bose Head Unit. So here are my questions.
1.Can i replace the tweeters even if i have the Bose HU
(if i could, has any1 changed just the tweeters, and does it make a big diff)
2.Can i change the stock subwoofer to get a better bass or will it sound the same since its coming from the same HU.
3.Ok lets say i want to change all my speaker but keep the same HU. Can i hook the new Speakers to an Amp by sending the HU signal to an aftermarket amp and then the new speakers.
Old Oct 24, 2005 | 01:16 PM
filtor1's Avatar
1. Yes
2. Better off adding an amp to an aftermarket Sub, even if you decide to use the stock location.
3. The best of the 3 options, althought the most expensive. You will need a Hi-Lo/LineOut converter to convert the stock signal to an RCA.
I see you live in NJ. PM Don, and see what he can do for ya AKA Pearl96Max.
Old Oct 24, 2005 | 04:42 PM
NismoGTR's Avatar
Originally Posted by filtor1
1. Yes
Thx man for the help....anwsered all my question.....and ill pm him.....THX again
Old Oct 24, 2005 | 08:01 PM
filtor1's Avatar
Anytime.
Old Oct 25, 2005 | 12:26 PM
NismoGTR's Avatar
Is this a good one.......
.http://www.crutchfield.com/S-YK6el40...&i=142SLC4#Tab.......
And will i have to run a new line directly from the converter to the speakers since the original wires run through the bose amp..............
Old Oct 26, 2005 | 12:03 PM
NisAznMonk's Avatar
Look for those pieces.
Pac brand:
ADD-NIS2
AMP-RCA
OEM-1
Once you have that, it'll connect directly to the back of the HU. From there, you'll just run new wires to an aftermarket amplifier. You'll bypass your factory amp completely.
Old Oct 26, 2005 | 12:20 PM
NismoGTR's Avatar
Where did u get that 1
Old Oct 26, 2005 | 06:43 PM
dlew329's Avatar
Nisaznmonk that is cool. I was lookin for something like that.
Old Oct 26, 2005 | 08:32 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Pac brand:
ADD-NIS2
AMP-RCA
OEM-1
And none of that is needed. Simply splicing RCA leads to the speaker wire behind the HU will do the same.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Violator
Sep 9, 2015 10:14 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
jfl330
Sep 4, 2015 01:44 PM
