where to wire amp
Old Nov 7, 2005 | 12:48 PM
dlew329's Avatar
5th gen amp wiring
I need to wire my amp to the battery. I cant seem to find an existing hole in the firewall to run the wire through. where can i find the hole or does any one know where a good hole is? I have a 5th gen.
Old Nov 7, 2005 | 01:07 PM
C MAX's Avatar
i go thru the speedo cable hole if possible. just pull the rubber gromet out and slide the power wire thru.
Old Nov 7, 2005 | 04:47 PM
dlew329's Avatar
Unfortunately i dont have my car right now, but i'll take a look at it tommarow. Any 5th gen owners know of any locations to run a wire through?
thanks
Old Nov 9, 2005 | 05:27 PM
03SE2HEAR's Avatar
Depends on the gauge. I'm sure you can squeeze a wire through the speedo grommet. I had no clearance issues running 1/0 underneath then up under the back seat. So far, so good.
Old Nov 9, 2005 | 05:38 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
- Remove driver side wheel.
- Remove wheel well
- Run wire through big-a'ss hole in wheel well from battery to amp.
[/THREAD]
Old Nov 10, 2005 | 06:03 PM
dlew329's Avatar
thanks a lot for the input
Old Nov 10, 2005 | 09:10 PM
TheBigDu's Avatar
Just to add a bit to Metal's suggestion, here are some pics I've had for a while.
This question gets asked a lot; maybe it's time for a sticky on where to run wires in various generations? Anyway, here it is for 5th gen:
1. Take out plastic wheel-well liner on driver's side. (This is a lot easier if you jack it up and remove the wheel.)
2. Find hole with hood-latch release cable.
3. Snake through hole into cabin, shouldn't be too difficult to do.
Pics:
Hope this helps!
-Brian
Old Nov 11, 2005 | 06:22 PM
WxAxGxS's Avatar
Very nice, TheBigDu!
Old Nov 12, 2005 | 05:47 AM
dlew329's Avatar
big du thanks for posting the pics
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
