Installed my amp/sub today, have a problem though =(
Old Dec 3, 2005 | 11:17 PM
1NICEMAX's Avatar
I installed my hi/lo along with my amp/cap/and sub. The amp is on and cap is getting about 14 volts. Everything's working except my sub. I tapped the hi/lo into my rear speakers. My sub doesn't have the slightest bump. Could it be my hi/lo is wired incorrectly?
Old Dec 4, 2005 | 09:15 AM
Trevmister1610's Avatar
ya check everything to make sure its all wired right
Old Dec 4, 2005 | 09:23 AM
AscendantMax's Avatar
did you forget to set the gains?
Old Dec 4, 2005 | 11:13 AM
unrealii's Avatar
Does your high/low have a gain setting on that too? Did your car originally have a factory sub? If so, it may be sending the bass signal to the sub rather than the rears. This happened on my old ford taurus.
Old Dec 4, 2005 | 12:33 PM
1NICEMAX's Avatar
What do you mean by setting the gains? This is the hi/lo I bought: http://www.circuitcity.com/ssm/Tsuna...oductDetail.do
I don't think it has a gain setting. It did not have a factory sub. Under specifications, it says: "Allows for the addition of 2 or 4 channel amplifiers to most factory systems including JBL/Premium or Bose audio systems." I have a mono-amp, is that a problem?
Old Dec 4, 2005 | 12:40 PM
unrealii's Avatar
Looking at the top of that, I see two holes for some sort of adjustment.
Old Dec 4, 2005 | 01:31 PM
1NICEMAX's Avatar
Yeah you're right. I checked them out just now. And I think they cracked as I was turning them. Here are the pics...
The *****... (I think)
And this is where it was attached originally before it broke.
Think those are the settings??
Old Dec 4, 2005 | 03:41 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
those are the settings. either buy a new hi lo or go ahead and bite the bullet and getto rig it
superglue a toothpick on there and turn them *****
Old Dec 4, 2005 | 03:47 PM
1NICEMAX's Avatar
***, and the worse part is I threw away the package. i can't even return it, I'm gonna go ahead and krazy glue the ***** back in there. lol
Old Dec 4, 2005 | 05:46 PM
nismos14's Avatar
§è~® f®ÈÄk
Lol also set the gains no the amp too that may be the problem. Make sure also that everything is making contact/hooked up properly as far as speaker wire, speaker wire in the box, all the terminals etc.
Lakersallday24
Nov 7, 2024 07:31 PM
kmitchel
Oct 28, 2015 09:46 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Trin1j23
Aug 12, 2015 08:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
