most bass w/o a sub
Originally Posted by NAPhi_Shift
how big are these holes? i dont really like the sound of drilling, but if its something that even a newbie can do, then ill do it. is there a installation guide to do this?
Problem with that is the rear speaker holes are really hard to drill straight down into with self tappers. You'd be better off doing it from underneath. Then re screwing them in from the top. Don't do it with the driver in position because you might just throw a screw right into the surround or cone.
Yupp.
All you have to do is put the speaker in the mounting location and mark the 4 holes with a marker. Then drill.
i have some JL Audio 6.5" 6W0's that should fit. they are subs and should drop in. i have yet to install them, but i have 4 more on the way to make 6 total. may be parting with some, but not soon.
Kevlo has the right idea with an IB setup, but there is a LOT that goes into doing that properly if that's the route you want to go. Namely you need to seal off the trunk from the cabin of the car and, take it from a guy who is doing it ... it's not that easy. It's tedious work. Work that will make and INCREDIBLE difference in the end, but if you half-*** it, it won't sound as good as it could or should.
I'll have pics of my install once it's completed ...
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
I just got me a skewdriver so I can do it too
