Dynamat Trunk Installation
Old Dec 26, 2005 | 02:21 PM
trebor317's Avatar
Ok I have a 00 Maxima and got for a xmas present the Xtreme Dynamat Wedge Pak. It has a 1 piece (4sq.ft) which is like 18" tall n 31" wide....somewehre around there i measured it earlier. I am planning to do the install today and put it on the lid of my trunk, has anyone dynamat'd there trunk?? I really just want any suggestions or input on how you did it or how I should do it . Also If I should go buy another piece from bestbuy, I dont mind buying one , I know its obviously better to get another piece but if I could get away with the similar results using just one pack that would save me money as well. Any suggestions/directions/tips on trunk install??
Old Dec 26, 2005 | 02:23 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Have you searched for Any info? Or did you decide to just post up with your fingers crossed that someone would answer and save you the time??
Old Dec 26, 2005 | 02:30 PM
trebor317's Avatar
I searched for 30 minutes on google and cmae up with some write ups but not on a 5th gen maxima did I find anything besides a few pictures
Old Dec 26, 2005 | 02:32 PM
Pearl96Max's Avatar
If you try on THIS forum, theres a sticky at the top of the page, kind of hard to miss...
Old Dec 26, 2005 | 02:43 PM
trebor317's Avatar
its not hard to miss at all....but the trunk and door link is not working...so I decided to post this up, seriously Im just looking for help not teh easy way out, if theres another link for trunk installatioins on here let me know but the sticky one doesnt work for the trunk link. So do you have any suggestions on the installation Pearl??
Old Dec 26, 2005 | 02:48 PM
trebor317's Avatar
Here are some pics of my trunk and stuff...
trebor317's Avatar
oh ya and FYI: I put that DVD there just for size purposes so you can see how big the mat is....
Old Dec 26, 2005 | 02:50 PM
Pearl96Max's Avatar
Just heat up the matting to make it more pliable. Then mount it on. Larger pieces are always good, and with the heat it will contour better to the curves/indentations.
Dont try to rush it, just take your time and make sure you prep the surface well..ie: alcohol or something of the sort.
Old Dec 26, 2005 | 02:56 PM
trebor317's Avatar
K thanks, what can I heat it with? Dont have a heat gun so will something like a blowdryer work?? Also Where do you think I should slab this piece on, as a whole piece or cut it out for certian parts of the trunk lid. Like Where those triangles are, should I place them in there and other places or should I put it as a big slab and place it where those triangles are but as a whole piece all along there? I dunno if Im explaining myself well but , It looks like you've done this before and I just wanna know wheres the best place to put this piece or pieces...whatever the case is. Thanks
Old Dec 26, 2005 | 02:58 PM
Pearl96Max's Avatar
A hairdryer will work, just alot more time consuming. You try the whole piece at once, but if your new to it (im guessing) then smaller pieces may be the better choice for you.
Old Dec 26, 2005 | 03:08 PM
trebor317's Avatar
so cover the whole area, not just the triangle parts??
Old Dec 26, 2005 | 03:09 PM
Pearl96Max's Avatar
correct. The back/handle of a screwdriver can be very helpful in pushing it down. If you have the roller, the handle actually performs better.
Old Dec 26, 2005 | 03:36 PM
djfrestyl's Avatar
Suspension Yoda
http://www.eden.rutgers.edu/~nbalani/trunk%20worklog/
In that folder are pics of my trunk dampened. The trunk lid took me 25 mins tops, with two layers.
Good luck and happy holiday.
Old Dec 26, 2005 | 04:39 PM
trebor317's Avatar
Cool thanks both of you for yalls help, the pictures were helpful too dj, I just came from autozone and bought some stuff, Im going to start this dynomat in about 30 minutes or so, I'll let you kno how it went, thanks again
Old Dec 26, 2005 | 06:16 PM
djfrestyl's Avatar
Suspension Yoda
Post pics.
Autozone for Dynamat?
That's new.
Old Dec 26, 2005 | 07:33 PM
Pearl96Max's Avatar
Post pics.
That's new.
I think hes referring to some sort of tools..
Old Dec 27, 2005 | 02:16 AM
trebor317's Avatar
Post pics.
That's new.
no I didnt mean thats where I bought dynamat, my bad . I meant I bought some stuff for the car, juss lil things new license plate stuff, bulbs, ect.
Old Dec 27, 2005 | 02:21 AM
trebor317's Avatar
Here is the finished product... so far. I plan to put more dynamat once I get my hands on another roll but for now this will do. I finished in about a hour...I had it on in less than 10 minutes but I took alot of time flattenin it out and making sure it was as flush to the trunk lid as possible...This picture was taken immediately after it was still kinda warm but after about 20 minutes when the mat cooled off, it was firmly secured on and I felt no gaps/bubbles at all as I ran my fingers across it. The picture kinda looks like its not flat but, its as flat as I could get it, I used a screwdriver and mini baseball bat to flatten/roll it out onto the lid....
Old Dec 27, 2005 | 08:57 AM
Pearl96Max's Avatar
Great job, especially for a first timer. Your learning quick.
Old Dec 27, 2005 | 12:45 PM
trebor317's Avatar
thanks alot and thanks for ur help pearl and also djfrstyl
Old Dec 27, 2005 | 01:15 PM
djfrestyl's Avatar
Suspension Yoda
Looks good man. Good job.
Get some more ASAP
Old Dec 27, 2005 | 01:32 PM
Pearl96Max's Avatar
Not a problem, thats what were here for.
Old Dec 28, 2005 | 09:21 AM
scheibler4's Avatar
about how much dynamat is needed for a complete trunk?
Old Dec 28, 2005 | 09:49 AM
djfrestyl's Avatar
Suspension Yoda
I used a full bulk pack of Stinger Roadkill in my trunk.
Old Dec 28, 2005 | 10:10 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Depending on the layers and the extent of which you wish to cover it, 40 sqft for the trunk itself, and around 10 to 20 layers for the trunk lid, depending on how many layers you wish to use.
Old Dec 28, 2005 | 10:12 AM
Another thing I would suggest is using some Great Stuff to fill in the gaps of the chassis on the trunklid...also doesn't hurt to get the inside of the lid. Additionally, if you take the lid off completley, it makes it ALOT easier to work with.
Here's what 20 sqft. will do for the lid...
Old Dec 28, 2005 | 06:27 PM
Tatanko's Avatar
Bacon Lover
Holy crap. That's how much I put on my WHOLE CAR
It's amazing what a measly 20 sq. ft. can do when placed strategically, though...
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
Hailstatejig
Sep 2, 2015 06:52 AM
