Radar Hardwire in 6th Gen? which wire?
Old Dec 30, 2005 | 11:04 AM
Ryals's Avatar
SHIFT_this
I'm wanting to hardwire my rader dectector to the fuse box in my 6th gen like I did in my 5th Gen. I have the wires ran, I just need to know which and what color wire to tap into so that the radar comes on with the car?
Old Dec 30, 2005 | 03:19 PM
MaxiBis's Avatar
Look at the Sticky here: http://forums.maxima.org/showpost.ph...4&postcount=18. The 2004 should be about the same. Use a DMM to test.
Old Dec 30, 2005 | 03:35 PM
Ryals's Avatar
SHIFT_this
Well after tapping into about 10 wires I did find a few that gave power, but the power doesn't turn off with the car. I'm still open to suggestions.
Old Dec 30, 2005 | 05:32 PM
CKOTuHA's Avatar
Why not just have it on a switch?
Old Dec 30, 2005 | 06:29 PM
kpr10is's Avatar
Check the sticky for the colors of the wiring at ytour ignition harness. Tap it off of the accessory wire.
Old Dec 30, 2005 | 06:39 PM
AscendantMax's Avatar
where did you run the wires? thinking of about hardwiring my escort in my 6th gen as well.
Old Dec 30, 2005 | 06:40 PM
Ryals's Avatar
SHIFT_this
Is that wire diagram for the fuse box just under the dash on the drivers side.
Old Dec 30, 2005 | 06:51 PM
Ryals's Avatar
SHIFT_this
I mount the radar by the rear view mirror. Ran the wire across the headliner and down the driverside Apiller to the ffuse box area, but I can't find a decent source to tap into.
Old Dec 30, 2005 | 08:04 PM
kpr10is's Avatar
Ignition harness. You know your ignition?...that place you stick your key into?...the wires are there, and they can be found under your dash.
Old Dec 30, 2005 | 11:00 PM
-Red-'s Avatar
Why the ignition rather than just tapping the lighter wire?
Old Jan 2, 2006 | 03:10 PM
Anethema's Avatar
radar
Ditto for the lighter, just be sure to fuse it.
Old Jan 12, 2006 | 07:16 PM
Ryals's Avatar
SHIFT_this
I just tapped into the auto dim mirror like the write-up said. works perfect!
Old Jan 15, 2006 | 08:15 AM
NitrousOxSys's Avatar
CAn i use auto dim mirror fuse to power up my remote wire for the amp????
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
JRod28
Feb 4, 2016 11:07 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
