Tweeter replacement
Old Jan 25, 2006 | 01:28 PM
bladerunr's Avatar
Tweeter replacement
Does anyone have recommendations on an inexpensive tweeter upgrade? thx
Old Jan 25, 2006 | 01:53 PM
MannyNJ2k2max's Avatar
to be ran by what? stock system?
Old Jan 26, 2006 | 07:41 AM
bladerunr's Avatar
Yes, the stock system.
Old Jan 30, 2006 | 06:35 AM
bladerunr's Avatar
bump......
Old Jan 30, 2006 | 04:57 PM
MyGray96SE's Avatar
I just installed some Infinity Refrence 1011t's in my '03. They sound great. I had to turn the trebel to -2 on the stock non-bose system I have. They run around $60. They just fit behind the pillar trim. I used high-temp double-sided tape to hold them in. The tape works great.
Old Feb 1, 2006 | 01:00 PM
bladerunr's Avatar
Thanks. Where did you get them?
Old Feb 2, 2006 | 06:16 PM
MyGray96SE's Avatar
You can get them online. I got mine at Crutchfield. Looks like the price went up. You can get them cheaper elsewhere though...
Old Feb 21, 2006 | 10:40 AM
ShIft_uR FacE's Avatar
help
i installed some tweeters in the a-pillar using the stock stereo and they only lasted about an hour then they died out...the factory tweets have a little plug that goes into another plug which runs the speaker wire...would that make any difference to splice b4 the plug or not? also is there anything i can do so that any other tweets i mite try n install dont crap out??? thanx...
Old Feb 21, 2006 | 10:59 AM
nismos14's Avatar
§è~® f®ÈÄk
Doesn't matter if you use the stock connectors or not. What tweeters did you use? Sounds like the tweeters are to be blamed nothing else, unless there was installation error.
Old Feb 21, 2006 | 11:22 AM
djfrestyl's Avatar
Suspension Yoda
PROBABLY because you have Bose, and it's not compatible.
The BOSE system runs at 2ohms, which is why your speakers blew.
Old Feb 21, 2006 | 11:23 AM
djfrestyl's Avatar
Suspension Yoda
blade, are you running a Bose system?
djfrestyl's Avatar
Suspension Yoda
Hot glue also works.
Old Feb 21, 2006 | 12:34 PM
i used audiobahn tweeters...they were free...they looked pretty nice but w/e...n no i dont have bose...so any suggestions on which i should buy now?
Old Feb 21, 2006 | 12:52 PM
nismos14's Avatar
§è~® f®ÈÄk
The bose system only runs at 2 ohms because of the speakers. That amps are made to run at 2 ohm stable as well, but adding 4 ohm speakers should only lessen the output, not cause them to blow. Unless there is another explanation for it? I'm pretty sure anyway that you can add a 4 ohm tweeter wired directly into it and be fine.
Old Feb 21, 2006 | 07:46 PM
djfrestyl's Avatar
Suspension Yoda
Are you sure you got your ohms right?
That's not sarcastic, it's a real question. You could be right. I haven't mastered loads and resistances yet.
Old Feb 21, 2006 | 07:55 PM
nismos14's Avatar
§è~® f®ÈÄk
Well the bose amps are actually stable to 1 ohm or close. The woofers usually test out near 2 ohm. If your adding a tweeter thats as low as 2 ohms your still fine, 2ohms + 2ohms wired in parallel = 1ohm. BUT hypothetically if you were to add a tweeter to any stereo, there shouldn't be a problem with it being added in because it won't affect the resistance that much because of the frequencies that it plays. Like when a woofer plays even if its rated at 4 ohms the actual may be as low as 3 ohms tested, the tweeter doesn't fluctuate as much from what i remember, so it will be a constant 4 ohms or whatever. Adding a tweeter can cause the AMP to blow if the resistance is too low, but the tweeter itself should still be alright.
Old Feb 21, 2006 | 08:24 PM
djfrestyl's Avatar
Suspension Yoda
Interesting.
So why do you think this guy's tweeters blew after an hour?
Old Feb 21, 2006 | 08:38 PM
nismos14's Avatar
§è~® f®ÈÄk
Faulty wiring, AUDIOBAHN quality... hard to say, even the stock wiring could be faulty.
Old Feb 22, 2006 | 03:17 AM
DukeDuke's Avatar
shift, how did you connect them to the stock wires? They should be fine, was there any smell or popping noise right before they blew? If I were you, I would double check your connection and make sure you hooked them up correctly. Since you are only going 2 speakers, go to walmart and get what is called a T-tap, and just t-tap into the wires with male connectors. instead of using your plug.
Old Feb 22, 2006 | 10:16 AM
Interesting.
...because what people dont take into consideration is xover and the effects of the resistance on the xover value the speaker sees at different loads....Thats why these 'speaker swaps' in oem systems are retarded and not so simple..
For example a 4ohm speaker with a xover of 800hz, would see 400hz @8ohm... So essentially if the Bose system runs in 6 or 8ohm impedance it shows a 4ohm speaker half or essentially lower filter- so if the speaker has a certain Fs , and its shows a value too close to it, or below it(than it can effectively, comfortably reproduce) it will blow...
Old Feb 22, 2006 | 12:08 PM
nismos14's Avatar
§è~® f®ÈÄk
Good points there. Some things I overlooked.
Old Feb 22, 2006 | 01:33 PM
Yep...say guesstimating the OEM tweeter is designed for a 3Khz xover being 8ohm...now toss in a 4ohm tweeter as a replacement and its playing at 1500hz...Now there are maybe less than a HANDFULL of caraudio, compact tweeters that can play comfortably below 2khz with a shallow slope(12db or higher), let alone a simple 6dbslope that i'm sure Blose uses...hehe, none that wont cost you less than $400-900 retail for a pair...
Old Feb 22, 2006 | 02:56 PM
nismos14's Avatar
§è~® f®ÈÄk
I knew that, just didn't apply it to this, even though I should have. I did all the calculations when I was making passive xovers for my bose way back when lol.
Old Mar 14, 2006 | 08:18 PM
maxunknown's Avatar
tweeters
got pics, i want to do the same!
Old Mar 15, 2006 | 08:55 AM
djfrestyl's Avatar
Suspension Yoda
The same as what?
Old Mar 15, 2006 | 10:04 AM
nismos14's Avatar
§è~® f®ÈÄk
He wants to blow out the tweeters :rockon:
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
