HU install problems
Old Mar 29, 2006 | 03:57 PM
I30tMikeD's Avatar
HU install problems
This is ridiculous. Been messing with it all day. It's really not complicated, I don't know why I am having problems
Replacing broken Bose with a Clarion HU. Have both a regular harness adapter and a Scosche adpater both from Crutchfield.
HU won't power on. All I should need connected to get it to power up should be the red (acc), yellow (12v), and ground.
There are two grounds comming from the car harness, one black and one black/white. And one ground comming from the HU. I am just connecting the black ground from the harness and the ground from the HU and leaving the black/white ground from the harness alone. I also tried grounding the the HU to the chassis and that didn't work.
I have an FSM and checked my pins to make sure they are correct. Checked the fuses in cabin and under the hood.
The antenna doesn't need to be connected for this to power up does it? Maybe there is a ground in the antenna harness that is causing a problem.
Gotta walk away from this for a while because it's really pissing me off. I am no audio professional, but I have installed a few HU in the past with no issues.
Any help appreciated.
Old Mar 29, 2006 | 04:18 PM
RA030726's Avatar
I'm nutty for Nissans
you need to plug in the antenna.
Old Mar 29, 2006 | 04:24 PM
ajbent86's Avatar
i agree......
Old Mar 29, 2006 | 04:33 PM
DcMaN's Avatar
nissan uses the chassis that the radio mount into as a ground i believe. But i always use my own ground with a ring terminal for the headunit.
Old Mar 29, 2006 | 04:41 PM
djbonsu's Avatar
yes...plug in your antenna...that should do the trick...
Old Mar 29, 2006 | 04:57 PM
djfrestyl's Avatar
Suspension Yoda
Floating ground FTL.
Try grounding your HU on it's own also, to a bolt or something.
Old Mar 30, 2006 | 03:34 PM
Nealoc187's Avatar
SLOW
I told your *** but nooooooooooooooo you didn't believe me...
Old Mar 30, 2006 | 03:50 PM
nismos14's Avatar
§è~® f®ÈÄk
HAHA
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
