Installing components....
Old May 5, 2006 | 07:39 PM
Max_N_Action's Avatar
hey i jsut got some components to replace my front bose. i took off the door and realized im gonna have a harder time than i thought. Firstof all, howdo u guys mount the new tweeter, do you remove that whole metal thing that the boseone is attached to or just to bose tweeter. also, how do u made the tweeter say in place? lastlly, i think im gonna put thje cross over where the bose amp would be. how do i mount that. this is my first component install and i dont know how you guys keep everything in place.... thanks
i wanna install this 2morrow beforework so quick responces would be nice
Old May 5, 2006 | 08:10 PM
djfrestyl's Avatar
Suspension Yoda
If you put your crossovers where the bose amp would be you have to run 4 sets of speaker wire (2 per side). I suggest mounting the crossover in your door or let them be in your kick panel. You can remove the entire metal bracket and hot glue the tweeter in place in your A-pillar.
Old May 5, 2006 | 08:13 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Psst..the Bose amps ARE in the doors.
Nipplehead.
Old May 5, 2006 | 08:15 PM
djfrestyl's Avatar
Suspension Yoda
Nipplehead.
Ugh, 4th gen, right. So tired.
There is also room where that big foam block is on the door panel. Use some metal strapping to mount it on the door and pull off the foam block from the panel.
Old May 5, 2006 | 09:01 PM
metal strapping? is the hot glue strong enough?
Old May 5, 2006 | 09:09 PM
djfrestyl's Avatar
Suspension Yoda
Yes, should be. Get the upgraded stuff from Home Depot, not the craft "low heat" kind.
Metal strapping...pretty flexible, about 1/2" thick, comes in a roll about 6 inches in diameter. Has holes in it every 1/4" inch
Old May 5, 2006 | 09:19 PM
ok cool ill get everything in theresome how
Old May 6, 2006 | 05:00 AM
NYC TAR's Avatar
djfrestyl
I want to install my components too I've a non bose. I've two stock wire going to tweeter and the mid. ( I know both wires are not connected to together.so I can't install the crossover there)
if need to how I do get the new rewire speaker wire in to the door? drill a new hole or put it thought the rubber harness cover
Old May 6, 2006 | 08:38 AM
djfrestyl's Avatar
Suspension Yoda
You have to through your kickpanel to get the wire out of the car. Once you get it outside you can slit the boot and run it into the door.
Or, if you're good, you can isolate the speaker wires before they go through the molex plug in the kickpanel itself...tap there and leave your crossovers in the kick.
I do installs for orgers, for a fair price, and you're local...food for thought...
Old May 6, 2006 | 08:50 AM
NYC TAR's Avatar
thanks for the help this speaker install is just temporally unit I get my amp
I'll let you install it if I ever get that arc amp from nismo
Old May 6, 2006 | 09:01 AM
1996blackmax's Avatar
So he is selling it after all .....
Old May 6, 2006 | 09:21 AM
djfrestyl's Avatar
Suspension Yoda
He changes his mind every other day....we'll see. He's not online otherwise I'd pester him about it.
Old May 6, 2006 | 05:58 PM
DcMaN's Avatar
in the 99 ive drememled out enough of where the factory amplifier sits and was able to place the aftermarket JL audio crossover into each door for the front components. If you dont mind taking a trip down to ct ill help you out if you get stuck
Old May 6, 2006 | 09:06 PM
wat did u use to hold the crossover in place
Old May 6, 2006 | 09:43 PM
Pearl96Max's Avatar
Buying it was the smartest thing hes ever done. Selling it would be the stupidest.
Old May 7, 2006 | 08:34 AM
Man....
Comon Parag, do the right thing!
Old May 7, 2006 | 02:38 PM
nismos14's Avatar
§è~® f®ÈÄk
I'm keeping it.... rest assured even if I don't install it for a year, it's going to be mine... though $500 is alotta money
Old May 7, 2006 | 03:06 PM
But worth it for that amp .
Old May 8, 2006 | 10:22 AM
DcMaN's Avatar
screws... Just make sure the screws are short enough so it wont puncture your windows splash shield.
Old May 8, 2006 | 10:29 AM
how come i cant just use the stock bose wires?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
