Running Amp Power Wire
Old Jun 17, 2001 | 02:50 PM
CUMax
I have a 2001 max and I can't find a place to run the power wire from the battery to the inside of the car for my amps. Do I need to drill a hole through the firewall? If so where?
thanks
Old Jun 17, 2001 | 07:09 PM
SWEETSOUND2001's Avatar
http://images.cardomain.com/installs...87_82_full.jpg
Old Jun 17, 2001 | 08:08 PM
Minimalmaxima's Avatar
I don't know how much they changed from 4th to 5th generation maximas, but in my '97, there is a hole in the middle of the fire wall near the top. There is a rubber stopper thing that covers a whole.I poked a hole through the stopper and put my wire through. Then I went through the firewall and then through the other wall of the cabin and pulled it down from there. If Nissan didn't change things too much, or they typically leave a hole in that spot, you might try it that way. If that hole is not there, try installdoctor.com. They might have something.
Old Jun 19, 2001 | 12:48 AM
shortchaz's Avatar
firewall spot
I have a 96 and put my wire in a stock grommet location. If you take off the front dirvers' side wheel and then the fender lining you will notice a big bunch of wires going into the car. on the inside it may take a little bit of fudging to find the wire after you put it through if it is a small wire, just be carefull and don't cut any of the small wires.
Old Jun 19, 2001 | 01:00 AM
shortchaz's Avatar
firewall spot
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
sake1bs
Sep 19, 2015 09:32 PM
conansriver
Sep 3, 2015 06:38 AM
